ARB Bumper and Warn winch
Ok guys, I ve done some searching but did not find what I was looking for.
I have an ARB bullbar and just purchased a Warn winch for it. Well My question is for you folks who have installed a winch in your ARB bumper. "Where does your clutch lever end up being?" As I see it mine will be towards the back of the winch and I will have to reach in to the bumper to access it. Does this sound right? |
I believe that is where mine is also.
It has been a while since I have had my fingers up there. |
Part of the install is to unbolt the clutch housing on the winch and rotate it so that the actuator lever is accessible via the hole in the front of the bumper.
In this picture, http://www.watrd.com/gallery/albums/...0891.sized.jpg Just to the right of the fairlead, you can see the lever through the access hole, right next to the P.A. speaker. |
You need to loosen the bolts and 180 the housing so the lever is in the correct location. Don't take it off just lift it enough to rotate it.
