4runner rear fender flare options
well i keep getting pulled over because my tires stick out too far so i ordered some fiberglass flared fenders for the front but i dont know what to do for the back. i need somewhere around a 4 inch flare and i cant seem to figure out who makes anything like that for the rear except the hanneman fiberglass bolt on flares but they are way to expensive, i think for just the flares alone it would cost more than the whole front fenders. any help will be greatly appreciated. oh ya and my 4runner is a second gen
Bushwhacker
the only bushwackers that i have found for a second gen only have like a 1.5 in flare.
i know that bushwhacker has a larger flare, you'll see some pics on here.......that's really your only option unless you want to spend some serious dough on those nordic ones...
http://bushwacker.com/fender.asp?mak...&search=Search
Yea, these? If you need more than that, you need to make your own or stop driving it on the street. Or take them super wide tires off. |
http://www.brettakantar.is/myndir/im...eda94d666b.JPG
Those big enough for you? Just learn Icelandic and you're set. Actually I've heard its not too hard. Andy |
I would first see what the law is concerning tires that stick out. Do they stick out that far?
Originally Posted by 89dlx
(Post 50839228)
i actually just found some universal 4.5 in flares from jc whitney that were only 50 bucks so ill see how those work out
Here in Spain we've to cover the whole tire. I've some OEM type fender flares (Simillar to the Corey ones pictured in that link) and I'm adding a rubber trim like those:
http://www.jcwhitney.com/autoparts/P...013135/c-10101 I wanted to go Icelandic (Not those pictured) but I never achieved to get a reply from them and also I prefer the rubber as it's flexible (Tree resistant :lol:) David |
ya i think the rubber ones should work out pretty good. oh and my fiberglass fenders just got here so i might have to post some pics once i get them on
do so. i'm a fan of fiberglass
2 Attachment(s)
Attachment 194695
Attachment 194696 Got the passenger side fender pretty much on. took about a half hour to get it where it is now but i still have some fine detailing to do but so far im very happy. They are from toyota fiberglass in case anyone wanted to know. oh and sorry for the crappy pics ill post better ones when i get them all finished up. |
that looks good! i like very much
Bushwackers. You will need to armor them. To wheel with confidence, at least.
http://redchili.smugmug.com/photos/2...38_ikZur-L.jpg |
:woo:
And a rare post from Red Chili and it's nice to see that sweet 1st gen which I can't recall seeing one so rust free. :banger: |
1 Attachment(s)
No speck of rust. Anywhere. Due to the fact that I rolled it a year ago and spent four months rebuilding it and swapping bodies and getting a fine paint job.
Tire coverage was a design goal; I was tired of slinging mud all over everything, plus you get less concern from LEOs. A wider track from the beadlocks would have worsened the issue. Bushwackers were about the only realistic option for 1st or 2nd gen 4Runners I could find, but then you have extreme vulnerability and they grenade badly. I think I fixed that... Attachment 70163 |
those are the flares i'm talking about. i think those look really good.
those are what i was looking for. and theyre bushwackers?? how long ago did you get them
Last summer.
Note, in the interest of full disclosure: the stock Bushwackers are made for the stock 4Runner, including the bumperettes, long gone on the Chili. The pickup version does not have them, but does not quite fit the 4Runner. I solved that by some hacking, gluing, and putty. Bushwackers are made of ABS, which means you can go to Home Depot and get ABS glue, cut out the lower section on the rear of both, and join the bottom to the shortened rear, using the sheet ABS that is now left over. Fill any gaps with spot putty. Oh, and the rivet idea Bushwacker had for attaching them SUCKS. Instead, I got small (6mm? 5mm? Don't recall) stainless button head allen screws and nylocks. Be sure not to over tighten. |
