3in Body Lift Will i have problems
i want to install a 3in body lift to my 3rd gen 99 4runner. Will i have to lengthen anything such as gas hoses or other wire's/hoses. Or will it be a painless install
Depending what kit you get the instructions will tell you most everything you need to modify.
My gas filler neck is OKAY, but it leaks a few drops when I fill up. No big deal. My stock intake tube no longer fit right, I had to flip the elbow to get things to line up. 18 year old rubber isnt that flexible anymore ;) Some trucks might have problems and some might not, it really varies. None of the small problems I encountered set me back more then a few hours. Here are a few tips though: Spray all of your body bolts with your favorite penetrent lube ( PB blaster, liquid wrench etc.) for at least a week before you attempt. I hit mine 3 times and they came off very easily. Make sure your truck can be down for a few days due to unexpected problems or broken parts. Another mode of transportation is great ;) A friend or two makes the whole thing alot easier/funner. Make sure you have a good floor jack and one or two bottle jacks, along with various lenghts of 2x4's and 4x4's. |
check out 4crawler.com he seems to sell the best BL's and has adapter and extensions for the miscelanus stuff that needs to be lengthend.
Originally Posted by JakeBhs09
(Post 50741064)
- http://www.4crawler.com/4x4/ForSale/...o.shtml#Taller |
