2wd to pre runner
Hi all I'm new hear I have a 1997 Tacoma standard 2wd model how do I make it a pre runner?
First, There is no set standard for anything becoming a "prerunner".
Second, It will all come down to what your budget is and how far you want to go with the build. The 5lug tacoma isn't the best platform to turn into a desert truck but it has been done. To make it a capable off road truck, your best bet is to look into a total chaos front end and a deaver leaf spring setup. If the budget wont allow that stuff, you might be able to find a lift kit from fabtech but that wont add a whole lot of performance in the dirt. |
Originally Posted by Robert m
(Post 52303760)
What?
If you mean you want to turn your 5lug 2wd into a 6lug 2wd tacoma prerunner, it wont happen. They use a different a chassis and suspension from the 4x4s but are missing the transfercase, front diff and axles. |
| All times are GMT -8. The time now is 02:07 AM. |
