2nd Gen RS9000 shocks for 1.6'' lift?
Hello,
I've been searching but I've not found... A friend of mine is going to put +4cm (1.6'' aprox.) rear coils and adjusting T-Bars in his 4Runner. I've found RS99187 as the rear shock for 0-1'' lift, but I've recommended him to put a little longer shock in the rear. What will be the part # for the rear Rancho RS9000's? Thanks and excuse if this has been answered before, I've been abre to find it. David PS: Fronts are RS99145 is ok? |
Easy to measure the length of shock you need then look up the part number:
http://www.4crawler.com/4x4/Rancho.shtml |
My friend it's a little... Clumsy with those things and he's far from me...
No one has a similar setup? OME or Downey's and Rancho RS9000's? Thanks, David |
I have Cruiser Coils and Rancho 9009s. My rear lift is more than 1.6" so they should work fine. Instead of cranking the t-bars, I would suggest ball joint spacers. See Roger's link above, he sells them.
Edit: The Rancho's also have C1839 stamped on them below the 9009. |
Thanks PAhydrohead.
I've also suggested him to add the BJ Spacers instead of crank, when I said "adjusting T-Bars" I refered to get the same lift, cranking or BJ Spacering hehe. David PS: It's ˟˟˟˟˟ing hot Spain this summer... I need :drink: |
