13'14' tacoma suspension on a 98' tacoma
Will the coil over from a 2013 tacoma fit on a 98 tacoma. I know the studs on the top of the coil are a different pattern but could you use the 98 coil over cap and studs on the 13' coil over. Seems like it could work. Also will the rear leafs direct fit or can I make a mix matched pack from both.
My friend just lifted his 13' and has his old stuff laying around. My tacoma hit 200k and needs some help. Riding on the bump stops with any weight.
Also will the wheels from the 13 fit on my 98.
Thabks guys. Great knowledge base here.
Gonna make a mix matched leaf pack and try to make the struts work. Seems like it could work will just have to use the stock top plate off the strut. Just not sure if the newer ones are longer. Possibly it won't work because of that.
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
Vargntucson
07-04-2015 12:15 PM
