Wire Connector for Starter broke during starter replacement
Hi all. This afternoon, I started the replacement of the starter in a 2000 Tundra Limited v8. All went well - I marked and documented all hoses and wires, removed the intakes, etc... until I went to remove the starter itself. There are two electrical connections - 1. the main wire that bolts on with a 12mm bolt (I'm guessing this is the main feed from the battery), and 2. a small wire that attaches via a plastic connector (from ignition?). When I remove the smaller wire the plastic connector broke, making it impossible to secure to the female portion of the connector mounted on the starter itself.
Is it possible to buy a new connector? Anyone have a similar issue? Looking at serveral Toyota parts sites, I can't even find a listing. Any suggestion on where to find a parts site with a searchable diagram / fiche? Thanks! Dave |
Originally Posted by davidbr93
(Post 52397145)
... 2. a small wire that attaches via a plastic connector (from ignition?). When I remove the smaller wire the plastic connector broke, making it impossible to secure to the female portion of the connector mounted on the starter itself.
On our older trucks that is the case: https://lh3.googleusercontent.com/K0...=w1337-h776-no |
You are correct. I've seen this called the exciter cable. The part of the connector that attaches to the wiring harness broke. Just a small piece of plastic, but there is nothing left to 'click' the connector on. Given the location, having it back out wouldn't be good. I'll go to a dealer today and see if they can find a listing. I couldn't find anything online. I did find a wire harness repair pdf at this link https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf but since these are diagrams it's hard to gauge if I'm looking at the right thing. The truck has 225K and running strong so I'm going to everything I can to find something that will work. Funny how it can be taken down such a small part.
