99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
T-100 2wd Suspension Vs. 4wd?
Old 08-17-2005, 07:16 AM
elripster's Avatar
Would anyone be able to confirm the 2wd T-100's have the same upper a-arms as the 4wd's?
Thanks,
Frank
Old 08-27-2005, 05:36 PM
NY T100's Avatar
I looked this up at the dealer and the a-arms (upper control arms) are different. They have different part numbers and are different physically as well. The difference is in the area where the 4 ball joint studs mount to the a-arm. On a 2WD a-arm there is an open slot from the hole between the 4 stud mounting holes (the opening is circular between the 4 stud mounting holes and extends out to an open slot at the edge of the a-arm). On a 4x4 a-arm there is a hole between the ball joint stud mounting holes and the edge of the a-arm is solid (no open slot). I hope this makes sense. It is much easier to see in a picture and I think some of the Haynes manuals have pics showing this. I believe the reasoning is that the 4x4 a-arm is subjected to greater stress and needs the edge reinforcement for strength.
Old 08-27-2005, 10:40 PM
jimbo74's Avatar
hey, i wonder if the 2wd bj spacer fits the tundra 2wd also?
nvdesertrunner
05-11-2020 08:18 PM
DeathCougar
04-01-2018 11:29 PM
yipyip45
08-06-2015 02:05 PM
landrunner
08-05-2015 09:18 PM
andrewtexas123
07-23-2015 11:22 AM
Quick Reply: T-100 2wd Suspension Vs. 4wd?
