Sequoia vs Durango
I had a durango and now I have a 02 Sequoia and like it much better. With the durango you could adjust the Throttle Position Sensor for better throttle response, move the Air Intake Temp sensor from the intake to another place to read the actuall outside air temp. You could bore out the trottle body inlet or put on another years TB that was 3mm larger and then bore it out. Then reset the computer after all that's done. Can these things be done to the sequoia and how do you do them. Also, I assume what goes for the tundra goes for the sequoia ie...air filter, exhaust systems, Cat converter etc.
Thanks in advance. |
dont worry about the cat as it is a highflow save your money also do you have the v8?
