99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
2006 Tundra drive shaft removal issue
Old 01-02-2017, 09:07 AM
manic00's Avatar
Hi, I'm new to this site.
I've been trying to remove my drive shaft, I have a 2006 Tundra XSP V8 2wd DBL CAB
My issue is, my drive shaft connects straight to the transmission, I'm guessing itll just slide out when I have the other end free. Following down to the bearing carrier the drive shaft goes straight into it.
Then connects a U joint, then straight to the back axle where 4 nuts hold it. Heres the problem those 4 bolts are part of the axle, So I'll have to slide drive shaft forward in order to get it free, Everyone elses tutorials I've seen,the drive shaft is held by 4 bolts with the head on the other side, so when you take the nuts off, you can slide the bolt out and the shaft would drop.
Not for me those 4 bolts are part of the axle itself, only the nuts comes off and the shaft is still sitting on the bolt studs.
Would I have to take the Ujoints off first?
I'm stuck here
Attached Thumbnails 2006 Tundra drive shaft removal issue-20170102_130230.jpg   2006 Tundra drive shaft removal issue-20170102_130243.jpg   2006 Tundra drive shaft removal issue-20170102_130320.jpg   2006 Tundra drive shaft removal issue-20170102_130345.jpg
Old 08-10-2018, 07:28 PM
Jose Manzo's Avatar
Did you ever figure this out?
i have the same issue
Old 08-11-2018, 12:28 PM
akwheeler's Avatar
take the nuts off, drop the carrier bearing and you should be able to pull the rear off of the rear pinion yoke and slide the slip joint out of the transmission.
Old 06-10-2021, 03:51 AM
Pat2008's Avatar
I'm stuck here
are you guys asking how to remove this you took the four nuts off stick a pride bar in there and pull Or am I missing something my drive shaft takes 10 minutes to remove with no power tools or air half inch Drive ratchets and one open-end wrench use the clothes site obviously 10 minutes completely out the whole thing front to back what is the problem you guys are having
RPlais12
03-28-2019 04:32 PM
d-wood
02-02-2016 05:46 PM
jake_v
08-27-2015 08:53 AM
Trail_Banger
10-04-2009 04:17 PM
neil_P_smith
01-16-2005 03:23 PM
Quick Reply: 2006 Tundra drive shaft removal issue
