99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
2005 Tundra - 4WD Hi Flashes, but no 4WD
Old 12-14-2018, 04:10 PM
Liked 0 Times in 0 Posts
When activating the 4WD dash switch, I could hear the transfer case actuator working and the forward drive shaft locks, But no 4WD.
In my trouble shooting:
I tried everything I found online: Backing while turning, tapping on both actuators while trying to put it in 4WD, etc. The A.D.D. motor sounded pretty weak when apply voltage to it, and would sometimes not even make any noise.
Both Transfer switches tested OK (continuity test).
After a lot of troubleshooting, I was able to get the truck into FWD by: 1) unplugging the A.D.D. actuator plug, 2) With the key on, I pressed the 4WD button, 3) Applied 12V to A.D.D. Terminal 2 (+) and 6 (-), the truck went into 4WD and the 4WD Hi light on the dash stopped flashing and stayed on, I then plugged the A.D.D. actuator plug back in.
Excitedly, I took her out for a test run. Everything worked as it should, wheels all spun on gravel, chirped when turning tight on pavement. I was able to go into 4WD Lo without a problem, then back into 4WD Hi without issue. I then took it out of 4WD and into 2WD without any problems. When I tried to put the truck back into 4WD, the problem was back (flashing dash light and no 4WD).
Thanks for any ideas where my problem might be?
Blue Latitude is offline
JRober91
07-16-2013 05:38 PM
EthanFreeman
12-13-2010 09:33 AM
pendrag
08-02-2010 09:37 AM
iHATEmyHonda
03-17-2010 12:33 PM
yoda-g2
14
02-23-2004 06:07 PM
Quick Reply: 2005 Tundra - 4WD Hi Flashes, but no 4WD
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
