THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics
13 Attachment(s)
Attachment 206498 Diode Dynamics is excited to introduce the SS5 LED Pod! [MEDIA=youtube]Pont8vdEmoU[/MEDIA] Featuring the highest output intensity of any 5-inch LED pod on the market, these auxiliary lamps have been designed for maximum functionality, with patented technology and custom-engineered TIR optics, all in a durable package. This high-output 5-inch pod can add tons of light on bumpers, ditch mounts, grilles, and more! Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the SS5 collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency. From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS5 serves as both the optic and main lens for greater efficiency and light output. Thanks to this patented and innovative technology, when coupled with high-intensity LED chips, the total intensity of the SS5 is much greater than other LED pods using basic optics or reflectors with a standard outer lens. Selectable Backlight. The Stage Series 5" LED Pods included in the White kit feature a selectable backlight with eight different color options, perfect for an extra styling accent, or for more visibility when you’re not using the main beam. Selecting your backlight color is easy - simply alternate the power on and off. There’s no complicated programming with a controller! The SS5's backlight fully illuminates the TIR optic, providing unique accent lighting that you won't find on other LED pods. NOTE: Due to the yellow lens, the Yellow kit is only available with an Amber backlight color. CrossLink. Our patent-pending CrossLink technology allows you to link up to eight SS5 pods together to create your own lightbar. Unlike other options on the market that use multiple pieces to link pods together, we have designed a single-piece CNC aluminum link. This provides extreme rigidity, but is fully adjustable, for both straight and curved configurations. And thanks to inset threaded mounts built-in to every SS5, there is no need to buy a special linking version of the SS5 for your setup. Click HERE to shop SS5 CrossLink Lightbars! Attachment 206505 Image courtesy of Panda Motorworks - SS5 Sport - Spot Beam Pattern Attachment 206506 Note: These output shots feature ONLY 2 SS5 Sport LED pods! Functional Patterns. Stage Series beam pattern options were designed with advanced optical simulation modeling, to shape the output in highly-functional beam patterns with high efficiency. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
White or Yellow. Stage Series SS5 LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road. Sport or Pro. Stage Series SS5 LED pods are available at two different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses nine high-intensity LEDs for 40 watts of total power. The Pro model steps things up in a big way, with over double the total power at 90 watts. Simple connections. All SS5 LED pods feature an integrated and waterproof DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire yourself, or select an optional Diode Dynamics wire harness. In The Box:
Snap-on covers. For states that require them, or for extra styling or protection, we also offer snap-on covers for your SS5 Pod. These covers are available in a variety of colors and keep your SS5 Pod clean and protected from dirt, dust, or whatever else the road throws your way! Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like your factory lighting components. They've also been put to the test on-road by racers and enthusiasts alike. If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com. PM us for the free-shipping code (U.S. forum members only) John C. Diode Dynamics |
1 Attachment(s)
Just a heads up!
All SS5 LED pod orders through 12/31 will receive a FREE snap-on cover for every SS5 pod purchased! Attachment 206453 SS5 snap-on covers will automatically be added to your cart during checkout. Limit 1 per SS5 pod. Don't forget, you can also send us a direct message for a free US shipping code! John C. Diode Dynamics |
1 Attachment(s)
Here is a closer look at the brightest 5" pod on the market!
Attachment 206452 Diode Dynamics - SS5 LED Pod Don't forget, we are giving you a FREE snap-on cover with every SS5 purchase through 12/31! This applies to all CrossLink Lightbars and vehicle-specific kits too! John C. Diode Dynamics |
1 Attachment(s)
Just a quick reminder!
This is your LAST CHANCE for a free snap-on cover with your SS5 purchase, on us! Don't miss out, preorder your SS5s today before 12/31 at 11:59pm CST! Attachment 206433 Stage Series LED pods featured in the image above: SSC1, SSC2, SS3, and SS5. Click HERE to shop SS5 LED pods! John C. Diode Dynamics |
2 Attachment(s)
Here is a closer look at our SS5 LED pods featuring our combo optic!
Combo pattern combines both the Driving and Flood optics, perfect for all-around use. It shines light downrange in a focused 30x20 Driving beam to punch with distance, and fills in the surrounding area to create a full 70x30 degree pattern. With a row of driving optics in the middle, and a flood optic on the top and bottom, this has been designed to provide extra light for every situation. If you had to choose, which color output would you go with? 3000K selective yellow or 6000K cool white? Attachment 206431 Attachment 206432 John C. Diode Dynamics |
1 Attachment(s)
Output like no other! With an incredible output of 406,000 candela, our SS5 Sport LED Pod shines light nearly a mile away! Attachment 206430 SS5 Sport - 6000K Cool White - Spot Optic |
1 Attachment(s)
Hey everyone!
We apologize for the delay but we're excited to announce the first batch of SS5s have began shipping yesterday! Click here to see a glimpse of our team assembling, testing, and shipping right here in St.Louis, Missouri. Attachment 206392 |
The FIRST 4Runner with a custom mounted SS5 7 Pod White Crosslink Light Bar System!
1 Attachment(s)
Attachment 206277 We're including free covers with every backlit Stage Series LED pod purchased for a limited time! This promotion includes covers with ditch light kit orders and crosslink lightbars. Which pods included our backlight feature? Have any questions or concerns? We're here to help. Click HERE to view our backlit Stage Series LED Pods! Don't forget, US forum members are eligible for a free shipping code. Just direct message us! |
2 Attachment(s)
Attachment 206274 ALERT! [SIZE=17px]All [/SIZE][SIZE=17px]SSC1 LED Pods[/SIZE][SIZE=17px] are NOW in stock and READY to ship.[/SIZE] Attachment 206275 [SIZE=17px]Plus, we're throwing in FREE snap-on covers with every backlit pod purchased until 5/23/22.[/SIZE] Click HERE to shop SSC1 LED Pods |
1 Attachment(s)
Attachment 206268 Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3. Get 15% off all LED lighting upgrades with code "USA22" during checkout! Plus, all orders over $300, will receive FREE shipping. Click HERE to shop Diode Dynamics LED Lighting products! Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale. |
1 Attachment(s)
Attachment 206262 Don't miss your chance to save 15% off your entire order of lighting upgrades! Coupon Code: USA22 Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT! Click HERE to Shop! Sale ends 11:59 p.m. CST | Friday, 06/3/2022. Note: Items on pre-order are exempt from the sale. |
New video discovered on YouTube showcasing our SS5 Sport LED Pods in 6000K cool white with our combo optic!
How does the SS5 Pro stack up again the Baja Designs LP6?
Check out the comparison video by Snowbound Customs on YouTube linked below! |
1 Attachment(s)
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout! Plus, all orders over $300 will receive free US shipping. Click HERE to Shop! John C. Diode Dynamics Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes. |
1 Attachment(s)
Attachment 206176 THE CLOCK IS TICKING! Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics. Click HERE to shop! John C. Diode Dynamics Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes. |
1 Attachment(s)
Attachment 206170 ALERT: LAST CHANCE TO SAVE 15% OFF!!! COUPON CODE: JULY4 Plus, all orders over $300 will receive free US shipping! Don’t wait...this sale ends TONIGHT! Click HERE to Shop! John C. Diode Dynamics Sale ends 11:59 p.m. CST on Friday, 7/8/2021. Cannot be combined with other coupon codes. |
1 Attachment(s)
Attachment 206070 ALERT: LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 9/9/2022, you can use coupon code "LABOR22" at checkout for 15% off your entire order of lighting upgrades. Plus, all orders over $300 will receive free US shipping! Don’t wait, this sale ends TONIGHT! Click HERE to Shop! John C. Diode Dynamics Sale ends 11:59 p.m. CST on Friday, 9/9/2021. Cannot be combined with other coupon codes. |
One unique feature of our Stage Series 5" LED Pods is the eight-color selectable backlight.
In today's video, we explain what a backlight is, how it is controlled, and how to select what color you would like! Have any questions? We'll be happy to help! |
2 Attachment(s)
Attachment 205989
Attachment 205990 No matter the off-road adventure, there's an SS5 optic for you! 😎 ▶️ Spot: Perfect for directing light far into the distance. ▶️ Flood: Perfect for lighting up anything at low speeds, or for trailers and worksites. ▶️ Driving: Great for general illumination at speed. ▶️ Combo: Great for providing extra light for every situation, combining both Driving and Flood optics. Click HERE to check out our SS5 LED Pods! |
