Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
How can i save rear frame & spring mounts ?
Old 06-18-2017, 04:26 PM
85redfj60's Avatar
Gotta 85 FJ60 that has somewhat nasty rust issues on frame channel in area where ( front) rear spring mount attaches to frame. Should I attempt reinforcing with steel plate by welding or drill & bolt newer steel channel sections on ?
Also, does anyone know of aftermarket company that sells replacement spring mounts/frame brackets for rearend of my LC ? - thanks in advance -
Old 06-18-2017, 04:35 PM
Fossilized
Staff
dropzone's Avatar
your best bet would be welding new plate (if the frame is even salvageable)
off the top of my head I would try specter off road (SOR), Man-a-fre, cruisersparts, proffits cruisers
I would google rusted frame repairs or check out IH8mud (cruiser forum) to see what others have done.
Old 06-24-2017, 05:40 AM
wyoming9's Avatar
Red face
Maybe post pictures of what your dealing with.
To some even a little rust is enough to scrap the vehicle
To others it is just a few hours work
85 is a long shot but have you checked if they can be had from Toyota
Lots of Newer years the parts will work just fine.
Old 06-24-2017, 06:20 AM
muddpigg's Avatar
Not sure of width of springs on an LC but allpro and LROF sale self aligning spring hangars.
X2 on concerns for condition of frame.
Old 01-07-2019, 02:17 PM
OlGrunt's Avatar
Your Frame is suffering from electrolosys it is unsalvageable anything you do will not solve the problem. sorry
Old 01-07-2019, 06:09 PM
Fossilized
Staff
dropzone's Avatar
What info do you have that shows his frame in unsalvageable?
Old 01-07-2019, 06:25 PM
OlGrunt's Avatar
please READ about KOBE Steel Scandal. Mid 80’s. It all suffers from electrolysis. It eats itself apart. It cannot be fixed.
Old 01-08-2019, 02:58 PM
Co_94_PU's Avatar
F.ear
U.ncertainty
D.oom
Provide some detailed links, or keep on trolling.
Electrolysis doesn't just happen on its own. It requires very specific conditions. Physical science, you might of heard of it.
Regardless this is a very old thread. Seal it, cut it out replace it, all very reasonable solutions to degraded metal.
Old 01-08-2019, 03:05 PM
OlGrunt's Avatar
You are either uneducated or misinformed. Electrolysis happens naturally when diisimilar metals are mated ot combined Positivie and negative nutrions fight against one another to create heat. Heat causes moisture and....... viola. Rust. Most of us learned this in high school.
Old 01-08-2019, 03:09 PM
OlGrunt's Avatar
May be old thread. But a very important issue for ‘80-84 60 owners.
Old 01-08-2019, 03:19 PM
Co_94_PU's Avatar
1.
CHEMISTRY
chemical decomposition produced by passing an electric current through a liquid or solution containing ions.
Again very specific circumstances, requiring an electrolytic solution. You don't have ion flow without the solution. Heat doesn't just magically produce liquids, much less a liquid of the required PH (ion content)..
I'm not saying it couldn't have been better steel. I am saying if you want us to read something you should provide a specific link that demonstrates your point.
And still regardless, clean it seal or replace it still applies.
Old 01-08-2019, 03:23 PM
OlGrunt's Avatar
You are quoting chemistry for a physics dynamic. Was talking at a molecular level.
Old 01-08-2019, 03:26 PM
OlGrunt's Avatar
I have owned a 83 fj60. The body was eating itself apart. I worked on many 60 series. All were either frame or body. Never both that I discovered. BAD STEEL. Cannot fix. My answer to the original question.
justdifferentials
Just Differentials
01-06-2018 09:39 AM
eurojoe
07-20-2017 11:48 AM
mcswny
07-03-2017 07:31 AM
Dbp510
06-16-2017 12:51 PM
Quick Reply: How can i save rear frame & spring mounts ?
