differential questions
first off, this applies to my 78 land cruiser. i am aware there is a cruiser section, but there are more people going through this section and i think this probably could apply to pickups as well...
last year my land cruiser starting making noises that sounded like it was coming from the rear end. it would only occur when i would be in gear, but off the gas pedal - kinda sounded like small engine brake on a semi or something similar. i parked it for the winter and now am trying to fix it, but i really don't know much about diffs. i probably should take it to a proper mechanic, but i like to learn and the satisfaction of doing stuff myself so here we are. before i tear into it, i figured i should at least try to get some suggestions as to what the possible problem could be. the flange area where the driveshaft mates to the diff has a lot of play. i can grab and shake the drive shaft a fair bit. based on this, will i likely have to pull the rear end out? am i better just to replace rear end rather than finding and repairing the faulty part? |
U joint
:guitar: |
I don't know a ton about diffs but when mine went bad I had similar symptoms and my drveshaft had a lot of play also. My pinion bearing was shot and it ruined the seal as well so I had gear oil pouring out like it was cool.
My solution was to replace it and retrofit a brand new TRD e-locker but if you want just go to the junkyard and pick up a 3rd member for 200 bucks or so and replace it yourself. Diving into taking apart and repairing 3rd members is not for an ameteur for sure. However if your LC is as easy as my 4 Runner to swap rear ends it should be fun and you'll learn from it too. |
Originally Posted by waskillywabbit
(Post 51449018)
U joint
:guitar:
Originally Posted by devldogs55
(Post 51449022)
My solution was to replace it and retrofit a brand new TRD e-locker but if you want just go to the junkyard and pick up a 3rd member for 200 bucks or so and replace it yourself. Diving into taking apart and repairing 3rd members is not for an ameteur for sure. However if your LC is as easy as my 4 Runner to swap rear ends it should be fun and you'll learn from it too. also, i've heard that with land cruiser diffs, there are coarse and fine spline gears. is it obvious to the eye which is which? |
If the U-joints are in good shape, the pinion bearings and preload are the next place to look.
when mine sounded like this and had play i had a chiped tooth. i would pull the trird and see if thats your problem
I have no experience with LC diffs but why not go 4.10 all around? Your problem does sound like what mine was. Bad pinion bearing
You can always drop the driveshaft and make sure the pinion nut is tight. Sometimes they back out. Unstake the nut, make sure it's tight and restake. But the bearing could be toast.
(Post 51449042)
I see... Well I've seen used 3rds at junkyards for 200 or less. The work shouldn't take you long either. That's not too bad I dont think
Originally Posted by 83
(Post 51449047)
Originally Posted by Brendan
(Post 51449033)
(Post 51449132)
would that still make the noise i was hearing?
(Post 51449047)
(Post 51467486)
pinion nut has loosened off. should i be replacing the nut and what size socket is needed? what are the odds that if i (replace and) tighten it that everything is good to go?
after scouring the town looking for a 27mm socket and only finding 26s and 28s, I finally found a 27mm in a miscellaneous parts box. bought it, brought it home and the damn thing is too small. serves me right for not taking the nut with me i guess...
Pinion nut is probably a 30mm.
:guitar: |
You could easily use a 28, or 30mm socket as well. That said, it would probably be cheapest to find another diff. Try EBI in Port Moody if you're stuck, they cater to Cruisers specifically.
off the top of my head i think originals might have been 32mm. its been 13 years since i've dealt with originals though.
Edit: that might have been 3 speed t-case nuts... get a 1/2" socket set. The new nut from toyota will be 27mm. |
Originally Posted by FlyingLow
(Post 51479539)
(Post 51479602)
the old one is 30mm just like the new one
| All times are GMT -8. The time now is 06:51 AM. |
