toyteclifts |
11-16-2017 06:33 AM |
New Product Release -
Hey guys, figured I'd let you know we are now offering a new "2 inch coil spring and full 2 inch coilover" for the 3rd Gen Tacomas!
Coilover Link: http://toyteclifts.3dcartstores.com/...a_p_1867.html#
https://www.tacomaworld.com/attachme...8990d1d985e177- Take your truck performance to the next level.
- Eibach PRO-TRUCK Sport Shocks are Made in the USA and built to last using a Monotube Design with 46mm Pistons, Larger Nitro-Coated Rods and Heavy-Duty Durable Zinc Coated Shock Bodies
- Eibach Pro-Lift Coil Springs - Front Lift coils are designed to increase ground clearance, for better off-road clearance and performance. The added suspension travel delivers a more responsive, more controlled ride over rough terrain, and gives you the additional wheel-well clearance to use bigger, higher-performance off-road wheels and tires.
- Legendary Eibach Ride Quality
- High Performance Handling & Stability—On or Off Road
Includes:- Eibach Pro Sport front shocks
- Eibach front Pro-lift front coils
- Fully assembled with new top mounts and Urethane bushings.
- Ready to install, no spring compressor needed.
- Sold as a pair
- Fits 2016+Tacoma
- Provides approximately 2" of lift - (2" average lift is achieved with coils and setting the shock adjustment on the bottom C-clip setting) Use of the top two grooves to get more than 2" of lift may cause a degradation of ride quality and is not recommended.
Coil spring link: http://toyteclifts.3dcartstores.com/...ma_p_1865.html
Designed to increase ground clearance, for better off-road clearance and performance. The added suspension travel delivers a more responsive, more controlled ride over rough terrain, and gives you the additional wheel-well clearance to use bigger, higher-performance off-road wheels and tires. - For use with Eibach Pro-Sport Leveling Shocks (Not for use with stock shocks)
- Coils are powder coated Silver.
- Provides approximately 2" of lift on the bottom clip setting.
- Designed for 16+ Tacoma's
- Sold as a pair, (2) front coils
*Note: Average lift measurements shown are for Pro Truck Sport Dampers when used in conjunction with Eibach Pro Lift Springs. The lift amounts are based on a stock vehicle with no added aftermarket accessories or additional weight.
