4.88 Gear Packages for 2016+ Tacoma
1 Attachment(s)
We now have 4.88 Gear Packages for your 2016+ Tacoma !!
Gear Packages are available for both the 8" & 8.75" rear axle configurations...these GP's come with Front & Rear Ring & Pinion Sets...as well as Front & Rear Master Install Kits & marking compound to check your pattern. No matter which axle you've got under your truck, we can gear it to 4.88 with the best aftermarket gears available straight from Nitro Gear & Axle. We also have ARB Air Locker units available for this GP if you want it locked & ready to rock !! This is an excellent option for those of you who roll big tires, wheel your truck, or tow often. Contact chrisv@justdifferentials.com for more info :) www.justdifferentials.com |
| All times are GMT -8. The time now is 10:14 PM. |
