Toyota Rear Full Floating Axle Flanges!
#61
A bump for a swell vendor...
just had mine welded on to give me a total width of 58.25" WMS-WMS. We did mill the inside of the flange so that we could index it to the bolt surface.
Flange shot, I had Black Hat Fabrications weld these on so I know they are STRAIGHT. It is worth my $$ to have someone with the proper tools make sure my rig drives straight.
Axle shaft seal is still in, this is an issue because my new axle shafts (still TBD) my not have a section of the axle designed for a seal in this location. Worse case scenario when building a Toyota FF is to seal the drive flange cap. So everytime you pop the cap to the flange you will get some gear oil.
#63
Thanks!
What are you guys doing for axle seals?
And, are there other axle shaft options besides longs and nitros...for the fellow who's wallet is getting lighter?
Thanks
Thanks
