prerunner fender question
Who makes the widest prerunner fenders? My tires will be about 9 inches proud of my fenders. Its going to be just a little taller than stock with 30 inch tires.
Thanks!
Thanks!
The front is 72 inches wide, The rear is 85 inches. The frame is 6 inches off the floor, 33 inch tires in the rear, 30 in the front.
However you do it, I can't wait to see it. If you want to keep the original body lines, extend both sides of your hood to your desired width. This would be pretty easy as both sides are basically flat from side to side and a little crown from front to rear. Change the mount location for the factory fenders and call it done
i have a Hellion Industries tundra one piece front end, my truck is 85 inches wide, fiberwerx might be wider, but why?
