toyotafiberglass - My sons 4Runner
so picked up this unit for $1.00
previous customer of mine , son's 4runner .. from Calgary AB . they had it in to the dealer multiple times , he gave me ALL the receipts .. very FIRST invoice is for engine replacement under the warranty recall from Toyota head gaskets , this one was so bad they replaced the short block and 1 head .. owner decided to replace the other head as well . all back together .. owner drove it for a1 year , and it started to run rough again . long story short .. dealer replaced throttle body , plugs , wires , alternator , and many other pieces .. over $10,000.00 spent to get it running correctly ! BUT then never did , so the owner "called it" and bought a new DOMESTIC vehicle . asked me if I wanted it for parts . I bought it !!! fired it up .. and suspected injectors right off the bat .. so I pulled the intake , and sure enough . I suspect , originally , the dealer broke the clip that held the injector plug onto the injector . Over time the clip vibrated off creating the stumble . They NEVER checked that again , IDKW ? anyway .. fixed it with a NEW connector , and put it back together , and now runs like NEW !! so , being Alberta registered , I decided to give it to my son working on it when I can here's what I have https://image.ibb.co/kDh9B5/IMG_1133.jpg https://image.ibb.co/fytGr5/IMG_1472.jpg https://image.ibb.co/dBnLJk/IMG_1473.jpg |
Happy Bday son
https://image.ibb.co/hRKpB5/IMG_1588.jpg replaced fronts also new smoothie cowl https://image.ibb.co/cLzBPQ/IMG_1601.jpg https://image.ibb.co/cNJ5jQ/IMG_1602.jpg https://image.ibb.co/mRaJ4Q/IMG_1603.jpg dash is toast .. so gonna replace that while I have the time . https://image.ibb.co/mwG2W5/IMG_1604.jpg https://image.ibb.co/fK4Zdk/IMG_1605.jpg |
Wow! What a bargain!!
Your son is a lucky young man.
$1 and just because of a bad injector clip, haha, you made out like a bandit and all of the work that was done to it. It is looking better already. Great score.
Originally Posted by Terrys87
(Post 52377862)
found some time this weekend ..
drilled the spot welds , and got the panel off . https://image.ibb.co/kqwyFb/IMG_1660.jpg started fitting the FRP panel . https://image.ibb.co/mhdpMG/IMG_1661.jpg |
R side "fit" .. now I can remove , repair and prep the interior metal for final bonding
https://image.ibb.co/iuDwmG/IMG_1666.jpg https://image.ibb.co/j270Dw/IMG_1667.jpg https://image.ibb.co/hmKrLb/IMG_1668.jpg |
You have to sell hoods and cabins, no more rust in our Toyotas with that :)
one day :)
fixing the rust , building new patch panels , and POR15 .. whew !!! just about ready to bond the 1/4rs :)
https://image.ibb.co/b3Lnfb/IMG_1675.jpg https://image.ibb.co/b7BFYw/IMG_1676.jpg https://image.ibb.co/bszDLb/IMG_1677.jpg https://image.ibb.co/c8SB6G/IMG_1678.jpg https://image.ibb.co/fa6DmG/IMG_1683.jpg https://image.ibb.co/nmeYmG/IMG_1685.jpg https://image.ibb.co/jdEAYw/IMG_1687.jpg https://image.ibb.co/bMjAYw/IMG_1688.jpg https://image.ibb.co/gjrDmG/IMG_1689.jpg |
body work begins
fitting tail lamps , and fuel filler lid https://image.ibb.co/eZCCkb/IMG_1696.jpg https://image.ibb.co/iQvnJw/IMG_1697.jpg https://image.ibb.co/nB4Eyw/IMG_1698.jpg https://image.ibb.co/nM655b/IMG_1699.jpg https://image.ibb.co/ceCCkb/IMG_1701.jpg https://image.ibb.co/d5r55b/IMG_1702.jpg https://image.ibb.co/bR59WG/IMG_1703.jpg |
done the back 1/2 ... for know anyway .. time to start on the front ..
https://image.ibb.co/cR3K0b/IMG_1713_Copy.jpg https://image.ibb.co/c4giRG/IMG_1714_Copy.jpg https://image.ibb.co/iXsORG/IMG_1716.jpg https://image.ibb.co/kDB6fb/IMG_1717_Copy.jpg https://image.ibb.co/jMsCLb/IMG_1718.jpg https://image.ibb.co/eBSORG/IMG_1720.jpg |
doors are next ..
got them done over the weekend , now ready to install https://image.ibb.co/iSUbGR/IMG_1721.jpg https://image.ibb.co/bNFiwR/IMG_1722.jpg https://image.ibb.co/f1gCqm/IMG_1723.jpg https://image.ibb.co/koViwR/IMG_1724.jpg https://image.ibb.co/m8yE36/IMG_1725.jpg https://image.ibb.co/fyNJVm/IMG_1726.jpg |
Looking great! Can't wait to do the same to mine :great:
Originally Posted by galooph
(Post 52379712)
Looking great! :
Whatta lucky son. :) |
front end bodywork & paint + some powder coating ..
https://image.ibb.co/k7ZKd6/IMG_1728.jpg https://image.ibb.co/ktvgrR/IMG_1729.jpg https://image.ibb.co/iywXy6/IMG_1731.jpg https://image.ibb.co/cNNGQm/IMG_1732.jpg |
