hahaha .. I have more people going ... whaaaatt on the engine color then anything else :) .. love it !
guess you'll have to wait and see just what I'm talkin' 'bout . |
I think it will look fancy! But I think it would look better with 24K gold flake! Go big or go home!!
Originally Posted by kawazx636
(Post 52269005)
1 Attachment(s)
Joel still workin' on the frame ... almost ready !!
https://cimg4.ibsrv.net/gimg/www.yot...1e9ff9145c.jpg . |
You sticking with the IFS or going SA? Please say IFS so I know that you are still a Toyota purist... :o) Doing my frame was perhaps the most annoying part of my build! The entire frame was thoroughly covered with that nasty tar-like undercoating that was popular around here in the late 80's/early 90's. Talk about a major PITA to remove!!!
I wondered how you did yours. I do the same thing. Getting in all the nooks and crannies takes a while but about the only way I know of doing it with out blasting it. Drive train looks great.
(Post 52270375)
Originally Posted by Terrys87
(Post 52270383)
2 Attachment(s)
Joel has been a huge help on this .. and to keep up with him today we had to mount the tranny and engine to get the positioning for the new mounts .
I used some round tube I had , worked out great ... https://cimg2.ibsrv.net/gimg/www.yot...1dce121af6.jpg Attachment 121048 Attachment 121049 . |
5 Attachment(s)
engine and tranny back out .. time to finish up the frame .
Attachment 121020 and front end reduced to just a pile of parts Attachment 121021 and with a little more work we're almost ready for the POR15 treatment Attachment 121022 Attachment 121023 Attachment 121024 https://cimg5.ibsrv.net/gimg/www.yot...2e69b9a08d.jpg . |
3 Attachment(s)
ok , so now we're done with the fitting of the engine .. time to make it perdy :)
first I started with removing the pan .. for those whom don't know , the original oil pan and pick up on the 5Vzfe wont fit this application . so as you saw in the previous pictures , I already powder coated the pan I need .. With the pan off , I can now drill the new dipstick location .. and install the new holder installed with a little red LOCKTITE just for "piece of mind" Attachment 121002 also removed the "front end" to replace with all new parts new oil pump , water pump , timing belt , bearings ect ....... Attachment 121003 https://cimg9.ibsrv.net/gimg/www.yot...79d8e5217f.jpg https://cimg2.ibsrv.net/gimg/www.yot...2f607d7b86.jpg https://cimg5.ibsrv.net/gimg/www.yot...fdf2264db7.jpg Attachment 121004 . |
Are those "cheater marks" on the cam gears that I see so you don't have to re-do the timing later?? Just kidding, I do the same thing!!! HAHA! I hate having to re-time dual cams!
I really need to get some of that chrome powder to give it a whirl! That stuff looks really good - makes the gold pop really nice too! I particularly like how it looks more like polished and cleared aluminum than it does chrome (or at least that his how it come across in the pictures) |
of course :) ....
I ordered some clear coat for the chrome powder , suppose to make it look more like chrome . I was kind of going for a gold and silver look , on these , and I think I have achieved exactly that ? I'm really happy with the colors , and I think it's going to go great with the brown engine bay color and exterior . |
1 Attachment(s)
frame is all "prepped" now ... acid etched and washed
https://cimg9.ibsrv.net/gimg/www.yot...f066f54e16.jpg wheeled it into the shop , and all prepped for tomorrow Attachment 120983 should be black tomorrow :) . |
You do have every nut and bolt out of that frame. You are making some quick work on this truck.
(Post 52271107)
check this out
[YOUTUBE] . |
done and curing overnight
Joel spraying , and I used the pressure pot to do the inside of the frame https://cimg4.ibsrv.net/gimg/www.yot...f8436eeaf0.jpg https://cimg6.ibsrv.net/gimg/www.yot...b9be63317e.jpg https://cimg2.ibsrv.net/gimg/www.yot...60a8ac4629.jpg https://cimg4.ibsrv.net/gimg/www.yot...a4d48648e3.jpg and the "machine" cleaning the front diff .. https://cimg8.ibsrv.net/gimg/www.yot...b3db130b3b.jpg . |
1 Attachment(s)
got the rear in .. just loosely , nothing torqued yet
https://cimg2.ibsrv.net/gimg/www.yot...6a661c0144.jpg blasted the front A arms , and some powder and new bushings https://cimg5.ibsrv.net/gimg/www.yot...d816d69d20.jpg https://cimg1.ibsrv.net/gimg/www.yot...e07562db72.jpg started installing the new lift , and got the front diff in place Attachment 120925 . |
4 Attachment(s)
little more today ..
still working on the front lift , so got the crossmembers , shocks , sway bar , axles , and a few other things Attachment 120900 Attachment 120901 Attachment 120902 also checked the rear harness for damage , and re wrapped https://cimg0.ibsrv.net/gimg/www.yot...8dfa561de1.jpg POR15'ing the frame , you need to remove all the "lock" clips , so this is what I use to lock the harness into place Attachment 120903 straps not yet tightened , as I may need to move the harness one way or the other https://cimg2.ibsrv.net/gimg/www.yot...f1e087c21f.jpg . |
