Frontier 4x4's 94 Tough Truck Toyota
#83
#84
Working on axles next. They are both Trail-Gear 9's, 3.5"x.250. The rear is currently being custom built since the diff is so far offset.
I do have the front here, it's getting Super Duty steering knuckles machined for high steer.
They look better when you get them. They got rained on and have been in the corner for a year so I cleaned them up some but still not as good looking. The machine work is top notch.
I got as far as calculating out all the measurements for the width I want. Should be going together tomorrow. 66" WMS with equal length inner shafts. Less spares to haul around.
#85
66" WMS, 6* caster. Pinion is offset so I can run the same length inner shafts. I stuck the inner c's in the oven and pounded them on with a sledge hammer. Tight fit.
I wanted to get the knuckles bolted up but couldn't find my camber/caster bushing for the upper ball joint.
#86
Trail-Gear unit bearings, 6x5.5. One of the 5 I have has been an excellent back door stop for the last year, lol.
Sticking with my common parts store/fewer spare parts approach I'm running the same exact caliper, rotor, pads, and brake lines on all 4 corners. The calipers are pretty cool, the bleeder and brake hose are interchangeable so they work left to right.
Brake Rotor, 13.25" diameter, drilled to 6x5.5:
Chrysler Aspen 2007 - 2009
Dodge Truck Durango 2004 - 2009
Dodge Truck Ram 1500 1/2 Ton - Pickup 2002 - 2010
Ram 1500 2011 - 2012
Brake Caliper, mine are salvage yard for now. I'll get new if they work out.
Chrysler Town & Country 2008 - 2012
Dodge Truck Caravan (Grand) 2008 - 2012
Dodge Truck Nitro 2007 - 2010
Dodge Truck Ram C/V 2012 - 2012
Jeep Liberty 2008 - 2011
Jeep Wrangler 2007 - 2011
Ram C/V 2012 - 2012
Ram C/V 2012 - 2012
Volkswagen Routan 2009 - 2011
Brake Hoses:
Chrysler Town & Country 2008 - 2011
Dodge Truck Caravan (Grand) 2008 - 2011
Caliper brackets are Currie Part #: 60-2013JKCBK:
Currie Enterprises CJ Axle Parts
Warning: Caliper mounting hardware on the left is wrong. See next post.
Ram C/V 2012 - 2012
Ram C/V 2012 - 2012
Brake Hoses:
#87
One thing I found out is the caliper mounts are different on 2 of the 4 salvage yard calipers I have. Not sure what vehicle the are off of yet. I didn't notice until I went to bolt up the 2nd caliper which obviously wouldn't fit like it should.
The one on the right doesn't fit. Left is what is needed to work with everything else.
I'm glad the first caliper I bolted on was the correct one. It might have taken longer to figure out that I had to different mounts if it the first one didn't fit. I would have assumed they were all like that.
#93
Dharris1986
28
04-17-2017 03:34 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
FS[MidWest]: 2010 Toyota Tundra DC $24500 OBO Bismarck ND
toy89yota
06-24-2015 01:18 PM
