puulboy's 'Wikid' 2007 FJ Cruiser Build-up thread
Wikid Toyota Super White http://i668.photobucket.com/albums/v...e/IMG_0115.jpg I remember when... Wikid was Sun Fusion Yellow http://i668.photobucket.com/albums/v...y/IMG_9244.jpg 2007 FJ Cruiser, Package 1 4x4, a-trac, locker, side air bags, FJammer audio etc Special stuff Total Vision Products Baja Camera System , Custom Overhead Console, 8 camera’s, 4 screens, digital switchers , ecu’s Quad Channel DVR/ motion sensing, gps tracking Center panel, cb mount, 9 switches Custom battery box , over passenger, rear, wheel Custom air compressor mount, over drivers rear, wheel Second skin audio, complete interior sound deadening/ insulation Gearing East Coast Gear Supply Nitro 4.56 gear’s Performance Doug Thorley SS ceramic long tubes, Y pipe and muffler Custom 3 inch pipe, through bumper, oval exit AFE Pro Guard Dry CAI Suspension Overland Warehouse/Radlo 2.5 3” adjustable Coilovers, Rears and coils custom valved for my FJ Extended rear swaybar links Swaybar relocate, bump stop extension Toytec hd rear links/ 1” Dif Drop Toytec 1” Bodylift Camburg 1.25" uniball UCA's Armor Ricochet Full underbody skid package Custom Laser cut, front skid. Lower control arm skids Rear shock skids Inchworm, E-locker skid Demello Hybrid Slider Wheels/Tires Method Race Wheels 16x8 4.5 backspace General Grabber red letters Spydertrax 1.25" Wheel Spacers Steering HD steering links Bumpers Road Armor bull bar front Bulldog 9500, Remote control Viking Synthetic Winch line/ thimble Metal Tech rear custom cut tube bumper Bushwacker Fender Flares Electronics/Communication Lowrance Baja 540c Navigation Cobra CB/Wilson 1000 antenna National Luna dual battery controller Red Top Optima for start Sears Platinum M-1 Marine Battery Engel 45 refrigerator Blue sea 12 circuit fuse panel Zantrax 1000 watt power converter Custom nine switch overhead panel, triggered to rear buss bar CTEK trickle charger/conditioner Lighting Lightforce Striker 170’s,PIAA 520 ions Vision X Tantrum rock lights/controller, remote Onzuim interior lights, dashboard lightbulb Off-Road gear BajaRack, utility rack Puma, 12v Air compressor, 1.5 gallon tank Rear bumper mount air chuck. Recovery bag, shackles, d-rings, straps, Titan air jack 48” hi-lift First Aid kit Tools Basic trail tools CV axle , tie rod, serpentine belt etc. Coming Soon… Fujitsu 730 Tablet PC for all off-road navigation, custom laptop mount LED exterior lighting, to be determined Custom badge plate, by Ricochet Expedition one, front bumper change? Sponsored gear Total Vision Products, Baja Camera System Overland Warehouse/Radflo, Suspension Ricochet, full skid protection Doug Thorley Headers/Exhaust Toytec rear links, body lift, dif drop Viking synthetic winch line East Coast Gear Supply, gears Method Race Wheels, wheels Go-Pro, HD Video Camera Total Visions, Baja Camera System http://i668.photobucket.com/albums/v...DSCN2510-1.jpg The story After a year thinking about rock spotting camera's. I was strolling the auto isle at Costco. when I noticed a licensed plate rear view camera. Cheapo 80 bucks. Momma just rolled her eyes. After the groceries were put away, I went to the garage Faux hooked it up, bent the bracket for the camera and double face taped it to the right side of the front bumper, aimed at the tire. I took the truck down the road and followed street cracks, with the screen THAT WAS IT... I located a company in Tucson called Total Vision Products. Rod and I spoke at length, about a simple four-camera rock spotting system. Three months later, the idea evolved into a Baja Camera System, which includes eight cameras, overhead console, four screens, digital switchers and a quad channel DVR with GPS Tracking. Rod designed the equipment for this system. Camera Views Include: Front approach & Rear Departure (wide view) Front rock spotters, left and right tires Rear axle camera Roof forward facing (wide and normal view) Rear Roof (normal view. Driver side views will be the front approach, rear departure, rock spotters, and axle cameras. Passenger side will be all roof view cameras. The thought behind this is using the driver side screens for utility and the passenger side for trail video. Cameras selected on screens, are all recorded to a quad channel DVR. Prewire in capabilities up to eight additional cameras, with two channels of audio. Suspension Overland Warehouse/Radflo http://i668.photobucket.com/albums/v...d/DSCN2824.jpg We are using the complete 2.5 Radflo System that they have developed. The suspension is designed with the weight of my build in mind. After having three different systems on that did not perform well, I finally have the right one. It handles flawlessly and smoothly on the road. It also handles everything I throw at it off-road. System comes complete with 2.5 coilover's, 2.5 shocks, springs for rear, sway-bar relocate bracket, extended, bump stop for rear, and they added extended sway-bar link for testing. Don't count this out as a high performing system. http://i668.photobucket.com/albums/v...0/IMG_3540.jpg http://i668.photobucket.com/albums/v...e/IMG_0226.jpg Gearing East Coast Gear Supply Nitro 4.56 gear’s After a Brief encounter with the skinny pedal, I must have chipped a gear in my stock dif. Here is the Hill where I think it happened http://i668.photobucket.com/albums/v.../IMG_38121.jpg Chase from ECGS helped outfit Wikid, with some new teeth. They sent out rear diff third member and front outfitted with 4.56 nitro gears, in turn I sent them the cores. I would highly recommend these guys for regearing By the time I limped home, there were 3 teeth.. ahh missing. http://i668.photobucket.com/albums/v...e/DSCN3224.jpg If you have some mechanical skills or can recruit someone with those skills , you can save some $$$$ doing the switch out , yourself. http://i668.photobucket.com/albums/v...e/DSCN3226.jpg Ricochet Skid Plates http://i668.photobucket.com/albums/v...e/IMG_0245.jpg Ricochet skid products are protecting the belly of Wikid. Brad, is excellent to work with and his skid plates are designed well. I have been abusing his skids since early 2010 with Cruise Moab, Sedona Fest, FJ Cruisers Summit and many local trails. They have been sliding rocks and still staying true to form. Full under body skids customized with a sexy, laser cut “Wikid” Lower control arm skids BajaRack http://i668.photobucket.com/albums/v...k/DSCN3588.jpg This is a customer service oriented company that has a well designed product. I started with the EXP rack, with a RTT. Now I have the Utility Rack, that gives me the ability to fit in my garage. I really like the new look and the construction is great. I have further plans for the rack to follow. http://i668.photobucket.com/albums/v...k/DSCN3586.jpg Doug Thorley Headers/Exhaust Doug Thorley has outfitted Wikid, with a complete exhaust. Long tube 304 Stainless Steel headers ceramic coated Y-Pipe and muffler In addition to this I had a local exhaust shop, Apache Muffler, run custom three inch tail section through the rear bumper with three inch oval tip http://i668.photobucket.com/albums/v...t/IMG_0081.jpg Here it is all trimmed up and done. http://i668.photobucket.com/albums/v...e/IMG_0276.jpg New General Grabber 315/75/16 red letters I pulled the skids to do a front dif oil change, plus painting the rest of them. http://i668.photobucket.com/albums/v...e/IMG_0481.jpg http://i668.photobucket.com/albums/v...e/IMG_0477.jpg I just installed the Camburg 1.25 uniball UCA's. What a difference in handling. I had a brand new set of All-Pro HD steering links I saved to do UCa's and links at the same time. Then took it in for an alignment . Our local network alignment knows their stuff. http://i668.photobucket.com/albums/v...e/IMG_0494.jpg http://i668.photobucket.com/albums/v...e/IMG_0474.jpg Thanks |
Very nice!
How are you liking the new flat rack from Bajaracks? I sure like mine. |
Wow, that is one awesome FJ! Excellent work! :great:
That is one mean FJ......nice job
How do you like the General Grabbers ? I keep checking those things out on line. How well do they do for highway use? |
