towing , trailer brakes ?
Anyone know if the 98 sr5 runners had a trailer brake control wire anyplace ? I figure I need to buy the 60 dollar control box thing , just wondered if there might be a wire for it from the factory ? I'm towing a 22 ft camper with electric brakes , is the reason I'm asking , thanks .
I'm not sure first hand but I would say it doesn't. The controller box includes the wire for the brakes, and most times you have to wire up a 7 pin pigtail harness for trailer brakes not the regular 4 pin harness.
It would help to get more views if this was in the tech section not the build up section. |
Yea I figure your right , I have the 9 pin and 4 pin combo harness, just wondered if they had factory wire , like some fords do . Thanks for your input
No wire for brake controller. You will have to run that yourself. Dont think toyota figured anyone pulling a trailer that size with a 4 runner.
Yea I hear ya on that one , 22 ft is large for the runner the trailer is only 3500 lbs , plus the top is on hydraulics that shrink it to half its height. I tow a 2000 lb boat and trailer almost daily with no brakes and can't tell its even there until I look back , but brakes on the camper would make me feel a little safer . Guess I'll look at the little brake box things at the auto parts store . Thanks . Anyone know of a name brand that's the best ? Or should I say " not a nightmare to install" ? Or should I look for one that's made by the same people that made my harness ?
It depends how often you will be towing. Some are basic and get the job done while others you can fine tune with different loads for electric brakes on a car hauler or something like that. Install should be pretty basic on any of them, wire colors should be standard so buying a matching brand should not be a concern.
Sweet , that sounds like the route I wanna go , do you know anything about running a wire for the 12 v + connection to keep things inside the trailer working , ie , fridge , lights , my owners manual for the camper says I can switch the fridge onto 12 volt mode when hauling and keep food cold , but I gotta figure out what wire on the harness does it , and wire it up . I had amps in my car before, hopefully I can use the power wire to wire it up . I guess the wire would charge the deep cycle in the camper ? Or the 12 volt converter ? Lol thanks for the electric brake help . Take it easy .
Your brake controller only powers the electric brakes when you press the brakes in your truck, to help you stop.
Yea I got that part figured out , thanks . I have another wire on my towing harness to run other stuff while in transit. Thanks for your help
Originally Posted by hoghead420
(Post 52113703)
How far are you driving to need a constant 12v power source to your camper? |
Probably from Ohio to California, stopping along the way for a day here and a day there , idk much about it . It says in the manual for the camper that I can kick the fridge into 12 volt , and keep stuff cold on the road , I do have a deep cycle battery in the camper so I think the harness 12 runs the 12 volt inverter/charger for the deep cycle , and all the 12 volt stuff inside stays running and the deep cycle stays charged off the 4 runner . Looks like I need to Google it up and see what's up .
Let us know what you find because I've never heard of anything like that
OK will do , might be a day or two . Take it easy
