Stealth 97 4runner Build-Up Thread
Old Oct 7, 2014 | 10:06 AM
specialblend's Avatar
Recently I've just been up to some rust repair. Rust converted and bed lined my rear axel.
Also scored a front tow hook for my rear. Got some tow straps and hi-lift.
Next up is a safari rack, might be getting one custom built and ordered rock sliders from 4xinnovations.
Old Oct 7, 2014 | 10:18 AM
Roark's Avatar
What did you use for rust convertor?
Old Oct 7, 2014 | 04:07 PM
I used this stuff: http://www.walmart.ca/en/ip/rust-con.../6000078877261
I hear POR-15 is really good too and am going to try it if this stuff didn't do the trick.
Old Apr 28, 2015 | 08:51 AM
So it's been a while sine I've updated this.
Recent mods have included a lift finally!
Front
ToyTec Eibach 3" springs
Bilstein 5100's (Tundra 5 notch on lowest notch).
1" Diff Drop
1/4" Top plate spacer
Rear
ToyTec Superflex springs (3.75" lift spring)
Bilstein 5100 rear long travel shocks
Extended SS rear brake line
2 OME 10mm trim packers on driver side with cones.
Before I installed the spacers on driverside, I had 3/4" lean. Front top plate spacer helped about 1/2", then I installed the cones and 2 rear trim packers and it's all even now.
I also did the junkyard bumps mod (http://www.toyota-4runner.org/3rd-ge...ump-stops.html) and made 2" spacers to bring them down more, since by themselves they are too short and are really soft.
Flex all around is great, especially in the rear. Only issue I've run into is driveshaft making contact with my gas tank skid. In the middle near a balance weight and at the rear u-joint. Was able to cut and fold back some of the skid plate to make room, then hammer it all back against the gas tank. I still need a tiny bit more clearance at the u-joint but it barely contacts. I tried to get the spacer between the gas tank and the frame out to trim it down but bolt is rusted/stripped now so would have to remove the whole tank to get at it, screw that!
Got 4xinnovation rock sliders welded on now as well which have saved me a few times now.
Stealth 97 4runner Build-Up Thread-1901298_10155472577420564_1311663097841424113_n.jpg
Old Apr 29, 2015 | 10:21 PM
  #25
barryldst's Avatar
Like your truck, looks really sleek! Looking forward to seeing the new lift.
Old May 1, 2015 | 08:53 AM
  #26
Thanks barryldst.
Added a flex photo to my last post. I did the tire spin test to check my axle ratios and am pretty sure I have 3.90 or so gears, was hoping for 4.10's because I want to go up to 33's.
I've wanted a rear locker for a while so I'm currently looking into re-gearing and locking the rear (not sure on what kind of locker yet), and getting 33's.
Old May 10, 2015 | 06:22 AM
  #27
flg8r22's Avatar
Lookin good man!
Old Jul 13, 2015 | 12:36 PM
  #28
Update
Installed CB recently. Got it tuned, haven't been able to test with anyone yet but it looks good haha.
Stealth 97 4runner Build-Up Thread-10984219_10155813055280564_5895543175992640484_n.jpg
Old Jan 25, 2016 | 09:31 PM
  #29
Haven't updated in a while but the CB got tuned and works good.
Got a rear 4.30 elocker third and matching front diff. We modified my housing and I got a factory ECU and switch wired up so it works as if it's from the factory. I get the RR Diff Lock light in my cluster too and it blinks until it's completely engaged, took a while figuring out the wiring and then finding time to do the axle modification but finally got it done and was worth it.
Got to test it out last weekend and it works great.
Now I've been looking into UCAs and have been eyeing the Total Chaos UCAs but they are pricey, especially if I order from the US to Canada right now, our dollar is crap. Probably the best price I found locally is $900 CDN, so it might have to wait.
Old Feb 18, 2016 | 05:59 PM
  #30
98runnerguy's Avatar
I am currently looking for the front mudflaps just like yours but I cannot seem to find any. I was wondering if you bought yours?
Old Feb 18, 2016 | 09:34 PM
  #31
They are stock SR5 mud flaps as far as I know. My truck didn't come with the rear coil rubber cones which I had to buy to fit some OME spacers to correct my suspension lean, and my buddy's 2000 SR5 was lifted and didn't have mud flaps either. Just luck of the draw with used vehicle I guess.
I'm going up to 33's soon though and wider stance with some backspaced 16's so I can fit the tundra brakes. So I'll probably have to find a good flare option.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
