MKtaco_98's 1998 Tacoma Build-Up Thread
#104
I wanna try it right now haha well have to go back out to Prairie city to try it out but I still have a few things to do with the locker it's in but not hooked up yet I'll post alot more pics of the locker being wired up the axle swap is straight forward, it will get dirty and look like the rest of the truck soon enough lol won't even notice
#105
Sorry its taking me so long to get the elocker harness installed moneys been a bit tight had to pay registration and smog so roughly $300 later im finally getting around too it, gotta love california
I installed my Blue sea fuse block over the weekend in prep for the elocker i should of done one of these as my first mod,
it needs a bit of cleaning up but everything works, ill post another pic of it cleaned up
I also went back to my stock headlights
#107
Ya only reason he hasn't installed it is he heard the spring fails inside it switches to open while your driving just all bad lol but being able to just flip a switch and change your oil is a sweet deal, good to hear you haven't had any issues I'm gonna give it a shot and install it, mike was saying you added something to make it more secure?
#113
im just gonna install mine... I found it in the closet earlier. Ill toss a hose clamp and a hose on it. should be nice to do oil changes with the skid plate on.
#114
Only takes a pair of linemans pliers to get those off..
#116
Blue Sea Fuse Block Install
Ive gotten alot of questions about this mod costs how i installed it so on so here it goes.
Amazon.com
Fuse Block Ato 6 Circuit With Ground $37.98
Blue Sea 5102 125A SEA Fuse $7.55
BLUE SEA 5001 FUSE BLOCK MEGA 100-300A $17.78
x2 Stinger Pro Series 4 Gauge Translucent Red Power Wire $1.49
x2 Stinger Pro Series 4 Gauge Translucent Black Power Wire $1.49
x2 Stinger 4 Gauge Crimp Style Ring Terminal ( 2 Pair ) $3.50
Ace Hardware
x6 4mm bolts ( be sure to check the bolts in both fuse blocks as they require different bolt lengths if you want it flush)
You might need to upgrade your battery terminals as well i found my negative terminal had no way of mounting to it, i grabbed a set of terminals from autozone lots of selections
Install is straight forward as you see in the pictures below
be sure to leave some slack in your wire if you install the fuse block were i did so you can still get to your stock fuses
enjoy
Amazon.com
Ace Hardware
enjoy
#118
Got my Elocker wired up today I used the harness from Inchworm, they give you everything you need and then some, I ended up removing the resistor from the harness it got way to hot, enough to melt the wires so I would recommend not using it works without it if not better,
Wiring Diagram
My Mess
http://www.youtube.com/watch?v=1IZII8ULOfE
Wiring Diagram
My Mess
