habanero's 1996 4Runner Build-Up Thread
#3441
Thanks Mr. Junk.
50....I didn't know I could get that old!
And a new distraction, a rattly noise suddenly appeared that appears to be coming from the rt rear drum, hoping for broken or misplaced spring or something. The flu is finally giving up harassing me, just down to coughing my guts out. I'll try to peek at it this afternoon.
The hubby gifted me a couple of winch solenoid relocation kits so I can cram the Zeon into the bumper. I think I'm only going to need one so am going to share the other with him.
#3442
Pulled the drum on the 96, nothing bad stuck out, pulled the abs sender, no damage to it. Put the drum back on and was able to recreate the squeak. It was cold, I am sick, it will wait further probing. At least it doesn't sound too alarming.
I also pulled the charcoal canister off the 96 and stuck it in the 99 to see if it'd throw a code in the 99...curiosity and the availability of a more finicky truck and all that.
I know the vsv is out of spec and that it occasionally makes a weird whistling wheezing sound that lead me to test it.
#3443
The truck's been parked since I pulled and reinstalled the drum until yesterday when I made a 40 mile round trip beer run (Schlafly Double Bean, Mexican Chocolate Stout, Blueberry Coffee Stout, Tasmanian IPA).
Now the abs activates at the end of every stop no matter how gentle. No abs light. I looked for broken abs wiring near the sensors, those all look good.
Also, I checked the rear diff fluid level (full) but still haven't pulled the axle on the right rear. The squeak is gone though.
#3444
96 4Runner 297,664 miles
Found the cause of the slight rattle/squeak that started on Feb 8th, pulling out of the parking lot on my way home from work. Parked it when I got home,
pulled the right rear drum on the 12th and saw nothing. I couldn't get it to squeak again until I reinstalled the drum, and it was very intermittent and hard to hear. Pulled the abs sensor to see if the axle shaft had been moving/rubbing against it but aside from some black junk it was fine. Wiped off junk and reinstalled.
Kept it parked until the 16th, when I drove it for a beer run. Could no longer hear the noise but oddly the abs was activating at the end of stops during this run. Checked the sensor wires all the way 'round and all looked good, was suspecting the problem was at the right rear again.
The snow melted and went away so I pulled the right rear abs sensor and sure enough, full of junk. With sinking feeling pulled the right rear axle. Bingo.
A lot of ughs were said, and several yeps.
There was never the tell-tale oil all over the tires from a wobbling axle allowing oil past the seal. Until the rattle/squeak there wasn't anything growling or too weird sounding. I'll get a new Toyota bearing and seals and have it pressed by Phase II machine because they know how to do it correctly. Getting one of these axles out is scary easy, remove tire, 4 nuts, brake line, parking brake cable keeper, remove axle.
Went through my records, the right rear wheel bearing had about 120,000 miles on it, last replaced with toyota parts in 2008
#3447
Sealed bearing and other bits on the way.
New parts on the way!
#3448
That bearing is toast! I'm glad your diligence to weird noises paid off. I'm curious why you ordered new parts though. Don't you have a green parts rig hanging out at your house?
By the way, my door lock actuators are going out on me and I'm going to replace them before the heat comes, since they work worse in hot sunlight. Thanks for posting good pic and instructions on how to replace them. I don't know if I'd tear into it without good info.
Also the panaracer fire's are still working out great. I did a 17 mile downhill run on an old train track and they were awesome. Plus the regular trips to drop off the kid at kindergarten on a one wheeled trailer with the 2 year old on the handlebar seat. No complaints so far!
#3449
Love hearing info here is potentially helpful, there's another issue that can cause actuator problems but I haven't experience it, just remember posts, so don't know the 411. I'm not sure, if all the actuators are failing at the same time it might be that issue?
The little MOPS motors are still holding up great.
17 miles of downhill??? Jealous!! Glad the tires are working for you, of all the tires I've run they're my favorites for the terrain around here. My Niner's wheels came with Mavic Crossmax Quest, not so much a fan of them.
At the rate you're going you'll need a triple tandem.
https://co-motion.com/bikes/trident_conv
(just don't look at the price!)
#3450
Double post? Need. More. Coffee.
#3451
FYI -- you don't actually need to get the bearings directly from Toyota. Our axles (the 96-00 ones) spec a 6308 double-sealed bearing which is a standard size. I was able to find some Nachi's for $25 each when I did mine. The factory original ones in there were Nachi's as well.
Or, maybe it's time for a full floater conversion
#3452
Yeah, I knew about the bearing and seals- not that I thought of them when I ordered my parts- and I'm not sure about the retainers. Phase II will re-use the abs ring so yay for that. Maybe I should've gone your route. Too late now, at least this should be the last one until another 120,000 miles, knock on wood!
Toyota 90363-40020-77 Bearing 64.72 is what I've got coming.
You know Mr. Rustbucket, thanks for bringing it up, It's good info that there's options for anyone reading this and needing to do their axles, Nachi, Koyo, I also saw Marlin Crawler has a kit though it doesn't seem to entirely match what's on there now.
#3453
#3454
As a general point of interest, The SKF bearing master catalog and the SKF master seal catalog Pdfs' (Google 'em!) convert virtually all manufacturer part numbers (including Toyota part numbers) into SKF bearing and seal numbers which, in turn, can easily be cross-referenced into just about any other bearing/seal manufacturers numbers.
Many of the Toyota bearings I have sourced by SKF numbers have turned out to be Japanese bearings, Koyo, Nachi, and the like.
#3456
Big huge PDF:
http://www.skf.com/binary/79-66347/457013.pdf
Years ago we all worked with multiple paper cross reference and spec books, calipers and magnifying glasses to ID and cross bearings and seals and lots of other things. Sometimes I really miss them even though a lot of it's available online.
#3457
More good info!
Big huge PDF:
Big huge PDF:
Saved for future reference.
Thanks for posting the PDF.
#3458
Where was all this info when I did my bearings?
I won't get the triple tandem, the kids have to pedal themselves. My 5 year old can ride his own bike, but for morning traffic I stick him on the trailer. My three year old does fairly well on a balance bike. However we do have #3 on the way, so who knows. I'm excited when I can take them with me on real trails. Seems like the three of you have a good time.
#3459
You're welcome, thanks to millball for inspiring me to look it up.
That thing is modular- you can add room for more! We won't talk about how it costs (!) as much as my truck did 13 years ago.
It seems like forever we're waiting for them to be big enough to enjoy our fun and like yesterday all at the same time, doesn't it?
Awesome and Congratulations on #3!!! It seems like yesterday you were expecting that first one.
#3460
Waiting for the axle. In the meantime I replaced the hood support doo-dad that broke this past week. Easy, didn't worry about breaking the clip to get it out since it's not re-usable.
If you ever do need to get it out it's a staggered clip
that you can get to from the front of the support. Very obvious. Push in to install, also obvious.
Also picked up a fuel tank strap for the '99 since the one it has rusted through and broke. This is available aftermarket from suppliers like Dorman but doesn't come with the insulator. Toyota's does:
And got some of grille clips: they occasionally break:
Also spent a bit of time deciding how I want to mount the winch in the bumper. It will likely require some cutting on the bumper, but I think I can avoid cutting the grille which is good because that would force me to abandon my Junkdrawerashi grille and put in one with center support. So far I think the solenoid pack will be over the right front fender. I'll have to move the cruise control and likely re-purpose the bracket.
