YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) (https://www.yotatech.com/forums/f200/)
-   -   Front u joint help (https://www.yotatech.com/forums/f200/front-u-joint-help-306581/)
Banquet Runner Dec 24, 2018 11:02 PM
Front u joint help
Howdy all. Merry Christmas. I recently bought a 2000 4 runner SR5. Been wanting one for a while and finally pulled the trigger. I have been reading up on all the forums and this one seems to have the most useable information. That being said I can't find an answer to my question. I've even searched multiple vendors without any luck. I have a common problem with vibration from just below 60 mph to just above 75. It seems most people solve this with the rear most u joint. I am planning to order oem u joints, but want to get all 3. 1 for the rear diff location and the 2 for the front drive shaft. It seems I have some play in the front most u joint. I can't detect any in the rear, but that one seems to be the most common.
My question is are all 3 u joints the same. I see a different part number listed for the limited vs the sr5. The limited shows the same part in all 3 locations 04371-60060. I can't find part # for the front sr5 driveshaft anywhere. I assume they're all 04371-60070 but would like to confirm before I order. If anyone knows or has a good site for looking up part #'s it would be much appreciated.
millball Dec 25, 2018 08:23 AM
This parts catalog is the bomb. Enter your machine type from the door pillar sticker and you're sure to get the right stuff.
https://toyota-usa.epc-data.com/4runner/
Banquet Runner Dec 25, 2018 08:34 PM
thanks 👍
