So the res was empty again this morning.
THis is retarded. |
no its not retarded.........
its a leak |
its a leak |
I cant figure this out. Why am I dumping coolant at such a rate, sometimes run with an empty res, but not overheat? Its running cooler than what it did before.
its a leak |
Originally Posted by Diesel_Freak
:) Ha totaly... Not to bum you out, cause I get frustrated at Cars/Trucks too, but your coolant system is a closed loop pressurised system... it may not leak untill you turn the truck on, then a pin holle will gush a gallon... Sorry you're having trouble, but at least you can keep filling up the coolant... Try droping an Egg in the radiator :lol: it worked to stop a leak on Mythbusters... No on second thought don't and forget I ever said to :shifty eyes:
Sounds like your leak is much bigger than mine, I'd definately start taking things apart and find the leak......
Ok, this IS retarded. Yesterday when I checked it, it was JUST ABOUT below the line. I didnt bother adding more. Today, I checked it, it was JUST ABOUT above the line. WTH? All the coolant I dumped int here, was Green Prestone, yet the res, is full of RED coolant. With the amount of coolant that was dumped, there is no way in hell there couldve been that much red coolant left to turn the green coolant so red.
Im confused. |
OK this is my first flaming but I think it is needed. Stop your Bi***ing, suck it up princess and get the thing fixed. You are simply repeating that you have a leak over and over but have not given us any additional insight into what it is, how to fix it, or how it happened, so what is the point, we know you have a leak. :mad2: We are not school kids that are in awe over coolent colors and pissing on the ground.
Who gives a rats A**. How much of the red fluid did it dump - at least 2-3 gallons??? If it dumped that much you would have overheated. Colors are grade 1-3. The more red then green it will over power it, as well other dies are more potent then others - who cares. If you are losing that much fluid you are going to cook the motor and then you will be whinning to us for months over a cooked engine when we all told you to get it looked at.
:alert: Seek professional help :alert:
And take your rig to the dealer too. :hillbill: :guitar: |
You may have opened up a big can of worms, NEVER mix red and green coolant, they react with each other and can cause many problems........
But yea, screw this. Not my truck, I dont care anymore. If hte engine blows or whatever, OH WELL. All my mods are going off htis weekend, adn being thrown up for sale. |
Originally Posted by Gangus2006
The jug said it was ok to mix with other coolant colors. It was the Prestone 50/50 stuff.
But yea, screw this. Not my truck, I dont care anymore. If hte engine blows or whatever, OH WELL. All my mods are going off htis weekend, adn being thrown up for sale. And yes, it is your truck. Your parents bought it for you and you have done plenty of stuff to it and it just wouldn't be fair to say "OH SCREW IT, I'LL THROW MY PAIN ON SOMEONE ELSE". There has been many times where you said that this is your truck (but it's just registered to your parents) to make yourself look good and now you just randomly change your mind. I am 17 too just btw, so think. Other than that, if you can't find the leak yourself, pay someone to find the leak, and then see if it's an easy fix or not. If it is fix it or else don't drive tje truck until you can afford to fix it. We all have to do it... Sorry for b****ing man. |
It could be the upper or lower bypass hoses. They're near to the firewall and hard to find/diagnose. I had both of them go bad and dump a ton of coolant on the ground, but it never affected my temperature. The parts are cheap and it was only about $200 with a pressure test afterward and new red coolant.
But yea, screw this. Not my truck, I dont care anymore. If hte engine blows or whatever, OH WELL. All my mods are going off htis weekend, adn being thrown up for sale. You ask for help. Folks offer solutions. You ignore them only to whine some more. Do us all a favor...de-mod the 4Runner, sell it and buy a Miata. :woo: |
But yea, screw this. Not my truck, I dont care anymore. If hte engine blows or whatever, OH WELL. All my mods are going off htis weekend, adn being thrown up for sale. If you paid for a single penny of it, then you wouldn't be saying that. BTW your motor is totally screwed, so you better sell it to me for really cheap. :laugh: |
lol...im going to get it checked today.
I was JUST A LITTLE bit pissed off at life last night. |
Dude, slow down and think and look for a minute. To start if you can change your oil, you find a coolant leak. First check and make sure the cap isn't leaking, then check the radiator for any leaks. Second check the hoses 1 on top 1 on bottom, ok after those are checked, check the heater hoses. Thrid if you haven't found that leak yet, you should be able to tell that it's running down from the water pump. Also as said earlier, it is a presurized system, so you may need to start the runner before trying any of this. Trust me your talkin to a hot head here, and sometimes the best thing you can do is step back and take a breather and THINK FOR A MINUTE
