YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Wrong torque setting (https://www.yotatech.com/forums/f2/wrong-torque-setting-178104/)
campintruck Mar 28, 2009 08:33 PM
I hope I haven't made a mistake by torquing my water pump bolts to much. I was in a rush to get it on before the FIPG set up and forgot to change my torque wrench to 14 ft. lbs.. After realizing what I did, I kept adjusting my wrench to find out what it was torqued to and it turned to be 28 ft. lbs. I also used the metal gasket with rubber membrane on the inside edge of the holes. Did I squeeze out too much sealant or don't worry about it and go on with the installation of my timing belt? Thanks, Frank
obscurotron Mar 29, 2009 04:56 AM
I haven't torn into my waterpump, but I'm going to guess the housing is what, aluminum? If so, the torque specs may be more for keeping you from cracking the aluminum than anything else.
That said, ain't it going to be a pisser when you put it all back together and the WP has a nice, steady seep? Yeah, it is. If it was *me*, I'd take the thing back off, clean off the FIPG, get a new gasket and install it properly. :)
GSGALLANT Mar 29, 2009 06:10 AM
You should add some info about the vehicle you drive in your signature, so that the answers you get will be more relevant.
You don't even need FIPG on the waterpump when you have the new metal/rubber gasket. Why did you put some on? I assume you installed a new waterpump... the one that doesn't have a groove cut in it for FIPG... If you re-installed the old waterpump (for some reason) then FIPG is what you should have used (and no metal/rubber gasket at all). Toyota re-designed the waterpump to use the metal/rubber gasket (with no FIPG).
