which wires do i tap into on my turn signals?
i got a set of arrow side view mirror turn signal deals off ebay and they dont look bad at all, i kinda actually like them. im wondering which wires colors specifically to tap into on my turn signals?
thanks
thanks
Tapping in
I am not positive but it seems like I remember it doesn't matter which wire you tap into as it is just a circuit so either wire as a tap should work. I'm sure I'll be corrected if I am wrong!
For the 2000 4R SR5:
The left turn is GRY/BLK (grey/black)
The right turn is GRN/YEL (green/yellow)
NOTE! My diagram says there is a junction box on the lower left side of dash with both these wires running through it (has power "in" from the switch, 3 wires out to front, rear, and indicator on dash). Splicing into any of the correct color there should work.
Post some pix, I was looking at those but the pix he had were lousy.
Do a tech/install page for them with photos!
