YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Window motor question... (https://www.yotatech.com/forums/f2/window-motor-question-28439/)
WSU4runner Mar 9, 2004 04:11 PM
My windows roll up and down really slow. Also, I can't roll some of them up using my driver controls. Any idea as to why this is?
Fink Mar 9, 2004 04:25 PM
My rear passenger window was like that...I took some silicone spray and sprayed a lining in the rubber grooves on the sides of the window.
About the driver side control, take the panel off and see if you see any burnt or corroded wire/contacts..mine had a contact that was completely corroded, a little knife scraping and cleaning and it works fine now.
Hope that helps,
Fink:devil:
WSU4runner Mar 9, 2004 04:58 PM
Thanks. I'll check all that out and hopefully it'll help.
