YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Which wideband and where? (https://www.yotatech.com/forums/f2/wideband-where-259115/)
Robb235 Sep 22, 2012 09:11 AM
I'm looking to put a wideband on my 99' 4Runner Limited (5vz-fe) since I think my front O2 sensor has gone bad. I'm planning to go boosted in the near future, so I'll need a wideband anywys.
Can I replace my stock O2 sensor with an aftermarket wideband? Will the computer read it ok? If so, which one should I go with? I don't mind if I need to cut the connector off the old (stock) O2 and solder it onto the wideband.
slacker Sep 22, 2012 04:28 PM
as far as I know .. no .. wide band is an "added" feature to stock . you will still need the stock o2's to satisfy the computer
Robb235 Sep 23, 2012 05:42 AM
Update.
I have Califorina emissions (2 cat converters) so I think mine are actually A/F sensors (i.e. wideband) as opposed to the old style O2 sensors.
I guess there's no reason to go after market then if I already have widebands on there?
frm_808 Feb 17, 2013 12:56 PM
http://www.innovatemotorsports.com/r...B_Shootout.pdf
If youre still looking, this might help you
Yodaforce Feb 17, 2013 03:18 PM
Yeah, you're going to have to replace the stock sensor.
The Innovate will help you when you go boosted to accurately monitor everything.
I would not recommend wiring a gauge to the stock sensors. Leave them alone and just get the Innovate kit and keep it stand alone.
