| CoedNaked |
Apr 10, 2005 07:53 AM |
Yeah - essentially a locked diff is a "mechanical" type of function. It's either on, or off. If it is selectable you have the ability to turn it on or off, if it's a lunch box locker, you can turn it on by simply having your foot on the gas pedal. There is no fighting it so to speak, and you as a driver will have to have abilities to hone it's advantages and disadvantages to push you on the 4wd trail.
Traction Control is a computer sort of technology and it is a reaction from rpm speeds that your computer receives from your wheels and then a mechanical solution by the computer I guess you could say, however you can't turn it on or off, only when the computer senses things are ok will it go off which is probably milliseconds when that wheel without traction regains traction. Traction control in my opinion is probably more convenient and a better on road worthy option. But I think many will opt for a locked diff because it offers no BS, no real serious cost, it can be fixed en route if needed with some tools, and it just plows you right up the hill or through whatever without any crap.
