Vibration at high speed.
Having problem with vibration in front suspension on 03 tacoma 4x4. only wobbles at high speed 55+.Feels like it coming from the right front wheel. Just had wheels and tires balanced, and front alignment. still did not fix the issue.
I know there was a recall on the lower ball joint for this year, wondering if this might be the case again? Also im running revtek spacer kit 3in(not happy with). and 285's Any ideas? |
if you think its the ball joint, lift the tire and hands at 12 and 6, try to move it.
did you have your tires road forces ballanced? 285's shouldnt be a problem to road force ballance, unless you have mt's! what kind of tires are you running? |
was just thinking that. im running Goodyear mtr 's. Just read a post on road forcing tires.
