YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Vibration with acceleration (https://www.yotatech.com/forums/f2/vibration-acceleration-262054/)
shandly707 Dec 1, 2012 03:07 PM
Hi everyone,
I have a '98 4runner automatic SR5 3.4L, 202,000 miles, which has run beautifully until today. While accelerating from a turn this morning a terrible screeching sound started, pretty sure from the engine bay though not certain, and would persist every time I reached 2,000 RPMs. Below 2,000 RPMs or in neutral and there was no sound, when coasting there was no sound. I parked the car and left it for a few hours. Later when I got in and started driving the screeching sound had disappeared, but the car was now vibrating (starting right when I put it in drive) and as I accelerated it continued getting worse. Pulled over, put the car in reverse and there was vibration. Neutral and there was no vibration. Drive, vibration. Sounds like driving on a rumble strip on the side of the highway and the car visibly shakes. While I was driving, the engine light momentarily flashed on, but quickly turned off.
I know there's been a lot of posts about a failed u-joint, which may be the problem, but I wanted to get someone's opinion on this specific problem. I thought it was a belt issue, but I had the timing belt replaced and front/rear differential service at 187,000 miles so I'm thinking it may be something else, however nobody else has described a problem that starts with screeching and turns into shaking. I just got back from jacking up the rear, where I tried rotating the rear tires back and forth to see if I could identify the source, and there is a slight knocking coming from somewhere around the u-joints and rear differential... so all signs are pointing towards a failing u-joint
BUT what explains the screeching and engine light?? Any ideas??
ZaCherry Dec 1, 2012 07:24 PM
If you didn't say you'd had the timing belt done already, I'd say timing belt.
ksti Dec 1, 2012 09:13 PM
Sounds like a cracked flex plate.
j2the-e Dec 3, 2012 02:33 PM
Maybe 2 unrelated issues. Maybe not. What is the check engine code? Might still be stored in the computer even the light turned off
