TPS resistance values?
Need help in getting the range values for a good tps. I am testing my tps (throttle position sensor) p/n: 89452-35030
I have two books, the FSM and Haynes. They give different resistance values between the terminals. One book says my tps is bad, and the other says that it is good. Could someone please provide the following five different resistance values for this tps: E2-Vta (open and closed) E2-idle (open and closed) E2-Vc The tps is on my 2001 4runner, that is the four terminal type. Thanks in advance! |
anyone?
nobody at all???????
Originally Posted by Cpate81
(Post 51421230)
I have two books, the FSM and Haynes. They give different resistance values between the terminals. One book says my tps is bad, and the other says that it is good. Could someone please provide the following five different resistance values for this tps: E2-Vta (open and closed) E2-idle (open and closed) E2-Vc The tps is on my 2001 4runner, that is the four terminal type. Thanks in advance! 1 -- E2 2 -- VTA2 3 -- VTA 4 -- C Casting numbers match yours. I'm not sure which one you are calling 'idle' For reference - FSM DI-266 and SF-28 This 4 pin TPS is a rare bird and I have never found a source for it. (which is why I have a throttle body sitting on my bench that I metered for you) Here are the numbers @73F: VC - E2 = 1.6k E2 - VTA = 0.8k closed / 1.4k full open E2 - VTA2 = 1.27k closed / 1.74 full open If you need any more #s let me know. |
| All times are GMT -8. The time now is 06:26 AM. |
