Tech update's
Old Nov 12, 2002 | 05:14 PM
Corey's Avatar
Co-Founder/Administrator
Tech update's
Two fresh articles hot off my keyboard.
1. Home grown C02 tank setup for airing up tires in the Off Road Enhancement section.
2. Headlamp upgraded harness for brighter light output in the Electrical section.
I can tell you right now I'll be doing the headlamp harness upgrade.
I have heard good things about it before.
Later on there will be a stereo head unit installation write-up to see what all is involved with getting the dash apart.
Old Nov 12, 2002 | 05:54 PM
914runner's Avatar
sounds good ill have to check them out!
Thanks Corey
Old Nov 12, 2002 | 06:23 PM
CLin9383's Avatar
corey, this may be a dumb question, but the headlight harness is for all gens?? thanks!
Old Nov 12, 2002 | 06:47 PM
Churnd
Guest
Posts: n/a
i'm not sure if it'll work with a replacement bulb type system as you have. if you could go look at your bulb and tell me what kind of plug it has (like a 3 prong), maybe we could work something out. if you have some kind of circuit tester, that would be even better, as we could see how it actually works also. or you could visit the website on the write-up and ask them.
Old Nov 12, 2002 | 06:51 PM
CLin9383's Avatar
hmm, my sig might be misleading...they are the stock housing, the only difference is the bulb....which is a h4 type...still work??
Old Nov 13, 2002 | 11:47 AM
Corey's Avatar
Once again the Tech section has been updated.
Bajataco has a friend who did a write-up on supplying full time power for your incab 12v outlets.
Check it out when you get the chance.
Man, the Tech section has grown quite a bit since last May.
Corey
ToyotaMD
Aug 17, 2018 10:16 PM
dzldust
7
Oct 6, 2015 05:39 AM
