switch
anyone know what this switch is? it is located on the left of the stearing wheel
http://img155.exs.cx/img155/6535/switch0010mo.jpg it is on a 1995 4runner sr5 4x4 22re |
Is the vehicle a manual?
yes 5 speed
It should be the safety overide. Turn your key to the on position and push it. the vehicle will start with the clutch NOT depressed, whether it is in gear or not. Be careful!!!
It is the driver seat ejector button! :hillbill: OR the clutch cancel switch....
:guitar: |
hehe i didnt fly out when i tried it but it doesnt start unless the clutch is pressed i tried. the light goes on when the ignition is on and unable to turn the light off till i turn the ignition off.
Im positive its the Clutch Cancel Switch (CCS). Insert key, turn to on, press that button, and start...
ONLY do that if you are absolutely positive that your truck is not in gear, and the e-brake is on.. |
ONLY do that if you are absolutely positive that your truck is not in gear, and the e-brake is on.. Not true, you can accually use it to drive your truck a short distance. Put you truck in gear, press the CCS and turn the motor over. Can be helpful in some situations.... |
thanks everyone it is a clutch cancel switch. I wasnt holding down the button while i turn the key. thanks again
| All times are GMT -8. The time now is 01:04 AM. |
