YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Stupid question (https://www.yotatech.com/forums/f2/stupid-question-26178/)
ts1 Feb 6, 2004 08:22 PM
Stupid question
I am trying to take off my factory hitch. I soaked all the bolts in liquid wrench and I could only get 3 out of the 8 bolts loose. I would kill to have some air tools right now. But without them, how do I get the last 5 loose? Any tips would be appreciated.
DrumheadAR Feb 6, 2004 08:25 PM
did you try a cheater bar???
(putting a pipe over the wrench to get more leverage)
Mike06 Feb 6, 2004 08:27 PM
I'd just take it to a shop and let them do it. They should not charge you more than a couple of bucks. It sure beats trying to take them off the hard way!
BTW, have you tried spaying them with WD-40?
:bigok:
Mossback74 Feb 6, 2004 08:28 PM
Cheater bar should do the trick. Or, get a bigger wrench
obxfishn Feb 6, 2004 08:46 PM
Cheater bar definitely, along with a good heavy duty socket and ratchet. Also try banging the bolts a few times with a hammer prior to breaking them loose but be careful not to damage any threads. Good Luck. ;)
PoBoy Feb 6, 2004 10:09 PM
I had to cut mine off...bolts snapped right off with air tools :welder:
