strange sound when turning.
This only happens after a cold start. When I turn the steering wheel it makes a noise similar to a sick owl hoot (or maybe a sea lion). I can kind of feel it it in the steering wheel. After the truck warms up it no longer occurs. Any thoughts are much appreciated.
Jeff |
Maybe the power steering pump or fluid level? Or a loose belt?
Ive got the same noise but mine does it in all temps on hard turns when climbing or going into a hole.
:pig:cake, sounds like a belt issue (fluid is stiff when cold, pump harder to turn, belt slips a little - my dime-store logic anyway)
BBB - if yours sounds like a creaking, all you have to do is lube your steering stops. |
Tankyuh Ceb I will do tnite while on the clock ofcourse.
Originally posted by BigBadBlue Tankyuh Ceb I will do tnite while on the clock ofcourse. Who actually works at work anyway?? I try to as little as possible. :laugh: |
Originally posted by mertztr Maybe the power steering pump or fluid level? Or a loose belt? Thanks guys... |
Originally posted by mertztr Who actually works at work anyway?? I try to as little as possible. :laugh: |
Cool...now the next question is, where did all the fluid go??
Ceb, I will do my best.... hehe |
So Tom are you for sure gettin the job in PA? If so you gotta make a stop in Indiana and wheel with us Attica boyz.
I dont think we're talking about same things nevermind:nono:
Originally posted by Toyo_Runner96 So Tom are you for sure gettin the job in PA? If so you gotta make a stop in Indiana and wheel with us Attica boyz. |
Originally posted by mertztr Cool...now the next question is, where did all the fluid go?? Originally posted by mertztr Who actually works at work anyway?? |
