YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Stiff Brakes (https://www.yotatech.com/forums/f2/stiff-brakes-259228/)
J-Ball Sep 25, 2012 08:13 AM
Stiff Brakes
Hey All,
My runner has lost it's power brakes. I've searched quite a bit and can't seem to find much about this. I still have brakes, it's all my leg can push to get the truck to stop.
I have;
replaced check valve
replaced vacume hose
ran truck, killed truck, then pulled check valve, I get a suction sound out of the booster. Doesn't that mean booster is good??
foot on brake, start truck the pedal remains constant. I do hear what sounds like a vacume sound under the dash when pushing on the brakes.
Also, I don't see any leaks any where around the master cylender or brake booster.
Full disclosure... I do have a leaking rear axle that completly staturated the D. side drum brake parts in 80/90 oil. Been like that for several years. After the power brakes went out I degreased and power washed the rear brake.
My only other idea to do now is to check all 4 corners and make sure brakes are not sticking. I did the front brakes about a year ago, cleaned and used anti-seize on the pins.
Any thoughts or ideas of what else the problem could be? What to check?
2000 4x4 4runner limited 225k miles!
WTF!?!? :facepalm:
THANKS GENTS!
J
James Woods Sep 25, 2012 10:02 AM
It sounds like the booster is bad.
J-Ball Sep 25, 2012 10:22 AM
Thanks for the reply James.
I was thinking that by running the engine, shutting it off, imediately pulling the check valve and hearing the vacume sucking out of the booster meant it was ok?
Any other ways to test for bad booster?
J
BMcEL Sep 25, 2012 10:37 AM
You already confirmed the booster is dead:
J-Ball Sep 26, 2012 05:21 AM
Thanks for the help guys.
Looks like I'm off to flea bay to pick up a used one with limited warranty.
J
