YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   steering problem... (https://www.yotatech.com/forums/f2/steering-problem-115381/)
blinkybill04 May 10, 2007 12:25 PM
steering problem...
so about a week ago i noticed if i turned the steering wheel right during a turn, it would be fine, but when the wheel went back to neutral (wheels straight) about a quarter turn off of neutral the steering wheel would stick a little bit. i didnt think too much of it at the time. well its been a week now and the problem has definately gotten worse. the steering wheel gets stuck at several spots when re-centering after a right turn, including being very stiff at the neutral position(wheels straight). when i wiggle the wheel a little back and forth it seems to help loosen the steering wheel up again, and it will be fine until i turn right again. anyone had this problem? my truck has about 156,000 miles on it.
BruceTS May 10, 2007 12:47 PM
have you checked your power steering fluid level?
blinkybill04 May 10, 2007 04:10 PM
actually no i havent.... i will though! i guess i can do that with no tools..ha
blinkybill04 May 10, 2007 04:23 PM
crap- the power steering fluid looks fine, i was really hoping it was that... any other suggestions?
BruceTS May 10, 2007 06:18 PM
check your ball joints, make sure the rubber boots are intact. If one did get busted and the grease all leaked out, it could be seized up.
