YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   squeeling engine... (https://www.yotatech.com/forums/f2/squeeling-engine-134716/)
4Runner202020 Jan 13, 2008 03:38 PM
squeeling engine...
ok so my engine squeel's (if thats how you spell it) only when i move. if i just rev the engine it doesnt make the sound but as soon as i move it picks up and gets faster as i go then when i shift it starts slow again. i got the whole tune up done at 137k and i'm at 149 now so i dont think it would be anything to do with that... any ideas
thanks
bobby
4Runner202020 Jan 13, 2008 04:28 PM
bump.
Elvota Jan 13, 2008 04:38 PM
What tranny?
From what you describe it doesn't seem like it would be a belt... but have you made sure they are all tight anyway?
YotaFun Jan 13, 2008 04:42 PM
Do you have a manual or auto?
4Runner202020 Jan 13, 2008 04:56 PM
manual and no i have not tested to see if they are tight
4Runner202020 Jan 13, 2008 05:04 PM
bump...
4Runner202020 Jan 13, 2008 05:24 PM
bump...
BajaRunner Jan 13, 2008 05:30 PM
I'd make sure the belts are in check. I have heard some weird noises come from them. It would be a lot easier to fix than do something with the tranny.
4Runner202020 Jan 13, 2008 05:33 PM
what could it be in the tranny. it sounds like its coming from the back of the egine. like towards the cab...
Elvota Jan 13, 2008 05:49 PM
Pilot bearing perhaps...?
How old is the clutch?
infiltrator Jan 13, 2008 05:56 PM
sounds to me like its your u-joints. any vibration?
ciscojay Jan 13, 2008 06:10 PM
I had a bad rear diff a while ago, had a horrid squeal whenever I moved. You could hear it mostly at city cruising speeds (25-45mph). On the highway it seemed like it went away but I just think you couldn't hear it over the cab noise. It ended up being a bad rear diff pinion bearing I believe. Luckily this happened 400 miles (!!!) before the warranty was out and had the dealership fix it for free. Boy I had to fight for them to fix that one. They were crying abuse/lack of maintenance...good thing I keep my maintenance records.
4Runner202020 Jan 13, 2008 06:51 PM
i can only hear it when i accelerate and there is no vibration so i donno if that rules out the u joints and or the rear diff. any thoughts
4Runner202020 Jan 13, 2008 06:56 PM
and i got the cluch replaced about a year and some months ago... i have no clue.
ciscojay Jan 13, 2008 08:06 PM
Sounds like it mainly happens when there is load on the drivetrain...could be a number of things. You'll have to isolate where it's coming from. I actually had some buddies drive next to me with their windows rolled down and sourced it that way.
4rnr4nick Jan 13, 2008 09:16 PM
Not to point out the obvious, but it could even be your brakes telling you they need to be changed...just a thought!
4Runner202020 Jan 14, 2008 09:04 AM
could it be the brakes considering its only when i give it gas while in gear acelerating? thats what i thought at first but then i ruled it out.
4Runner202020 Jan 14, 2008 09:50 AM
bump?
KdF Jan 14, 2008 10:00 AM
Put it up on 4 quality jack-stands SAFELY.....make sure it does not move when you shove on it real good, start it and get under there whilst its in gear runnin.
We can only guess on a NG without actually hearing it.
