Squeaky sound after weekend mods
Hey
Has anyone found that they have a squeaky sound in their rear end after installing poly bushing to the end links, as well as a spacer to the coil springs? |
that is actually quite common poly is louder than rubber... did you grease them? there is special poly lube that makes it so they dont squeak
so the squeaking is the end link bushings...not the coil spacer?
i was in a rush to install the bushings....didnt open the lube.. guess ill have to redo it...... |
