YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Speedometer Problem (https://www.yotatech.com/forums/f2/speedometer-problem-20700/)
rena Nov 10, 2003 08:31 AM
Speedometer Problem
Hi, I have a 1992 4Runner and the speedometer some times work, and some thimes do not, almost the time it do not work.
Please give me some advice on how can I fix it.
Thanks
dajabr Nov 10, 2003 09:29 AM
Rena,
Primero encuentra un FSM, Manual de Servicio de la Fabrica. Tendra detalles sobre todas partes que podrian tener problemas.
En cual manera funciona o no funciona? Parece electrico or talves con el cable? Ruido o sin ruido?
Guys, is the second gen a speedo cable or electric?
nightsurfride Nov 10, 2003 09:32 AM
According to Mtchell On-Demand, if your '92 is V6 4x4 with Auto. Trans. then you should have a #1 speed sensor Transmitter on the right rear of the transfer case. Also there should be a #1 speed sensor reciever on the back of the speedometer. I would probably start with the transmitter because it is easier to get to and check for anything obvious like melted/cut wires. As far as specific tests on the sensors and wires, a more detailed service manual is desired for exact procedures and test result values.
Robinhood150 Nov 10, 2003 11:13 AM
FYI, Rena asked about this about a month ago: https://www.yotatech.com/forums/show...threadid=19293
Rena, what have you checked so far?
The autos (like mine) have a gear driven speed sensor outputing an electrical signal to the speedo.
Krash Nov 10, 2003 11:38 AM
If I remember correctly, I know in the trucks around 92 is when they started switching over from mechanical speedo to electrical. If I were a betting man, I would bet that his is electrical, but thats just me I'm no expert.
rena Nov 10, 2003 12:39 PM
Thanks all of you, I am new with Toyota brand, I just bougth my 4Runner 1 and a half month ago and I am happy with it.
Here in Ecuador there are a lot of places to go out of road, I used to have a Cherokee, but the 4 Runner is much better.
Regards,
Renato.
By the way I bougth a Chiltons manual I will receive it very soon, I want to buy the owners manual, but here in Ecuador it is impossible.
dajabr Nov 10, 2003 01:12 PM
Yup, you're a natural. Another soul saved, hallelujah!
Robinhood150 Nov 10, 2003 03:00 PM
Can you order an factory service manual from a US dealer? I'm not sure if you can get it in espanol, but you might want to email TOR, here on the boards. He is a parts guy for a dealer in texas. Maybe he can send you one, and maybe even a spanish one.
Weasy2k Oct 25, 2004 10:33 AM
92+ are electric for sure....and my dads 93 just did same thing eventualy it just died....
User 051420 Oct 25, 2004 10:55 AM
Last year........... :hillbill:
Nathan Buchanan Oct 25, 2004 10:55 AM
Hey Rena-
I've got the field service manual for the '93 right here: http://personal.utulsa.edu/~nathan-b...fsm/index.html
It's better than paying 80 bucks
Weasy2k Oct 25, 2004 11:17 AM
hehe i brought it back to life :) i was doinga search didnt realize it till i posted :P
thanksfor the field manuel too its excactly what i needed while i wait for my book to arrive for this thing
rena Oct 25, 2004 11:49 AM
Thanks Nathan, I will check the link rigth now.
Renato
Krash Oct 25, 2004 12:12 PM
ooooh its bring back the old threads week... :D
Weasy2k Oct 25, 2004 12:39 PM
Well i have a code 14 and 42
is there a way to test the VSS i have it sitting infront of me now but i looked on that online thing and couldnt find a page with it...now i gotta search for this ignition problem gah
KING Oct 25, 2004 01:11 PM
From Ecuador? Awesome.
Paul H. Oct 25, 2004 03:10 PM
Rena, this is starting to be a common problem with 92's for some reason. Do a search and you will see all of the members who have had to replace their speedos recently. Mine was doing the same as yours before it finally quit altogether. you will probably end up replacing the speedometer to finally fix the problem. The speedo runs for about $150 american. Good luck and I hope this helps.
rena Oct 25, 2004 03:29 PM
Thanks to all of you, By the way my 4Runner is broken, I have to change the Crankshaft, the part is comming from Florida, so I am going to be out of circulation for some days.
My 4Runner is about 95.000 milles, żI dont understand why the Crankshaft is broken?
Weasy2k Oct 25, 2004 07:44 PM
The crank shaft is broken? how is that posssible?!
rena Oct 26, 2004 07:19 AM
I mean is in bad condition, not broken, I need to change it.
