YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Small problem (https://www.yotatech.com/forums/f2/small-problem-3594/)
prolax13 Nov 20, 2002 04:19 PM
Small problem
Hey,
My friends and I were driving around last week when we noticed my right rear tail-light was burned out. The next night, I noticed it had turned back on. It stayed on for a day or two before turning back off. I went to the local autoparts store and got a new bulb and installed it. At first it was fine, but eventually the problem persisted. I checked all the wires and none were coming loose or anything. Anyone got any ideas? Im not a genious with cars yet and I dont wanna get a ticket for a burned out light.
Thanks,
Dave
Hbum Nov 20, 2002 05:31 PM
The only thing that comes to mind is dirty or rusty contacts in the bulb socket. You might try to clean the inside of the bulb socket. Try do do it with alcohol or some type of solvent first. Sandpaper is the last resort. The contacts are usually plated and will rust faster if you sand the plating off.
Good luck and let us know how you make out.
Dr. Zhivago Nov 20, 2002 05:33 PM
Make sure the bulb is pushed in until you feel a solid click. The design of the sockets is such that the bulbs can work themselves loose on rare occasions. Just make sure to push the bulb in firmly.
Hope this helps.
Dr. Z
prolax13 Nov 20, 2002 06:11 PM
Thanks guys. Il try these tomorow. Right now im gonna catch some Zs. :yawn:
Later
Dave
