Slotted rotors...which way do they go?
Okay, this might be a really dumb question. None the less, it's one that hasn't been asked or answered here. I searched.
I have a set of slotted rotors I picked up cheap a couple months ago. I was *thinking* about installing them this weekend if I don't go wheeling with a couple other members here. Which way should the slots point? Pointing towards the front or rear? |
say your truck is facing that way <--------- the slots should go /
hope that helps |
That helps. Thank you!
EDIT 2: After some research and other opinions I have changed the picture.
I think this is what he's saying: http://www.drwastaken.com/temp/rotor.gif Edit: I guess I was too late. |
are they even directional? i dont think it matters, the slots are more for heat dissipation than anything else.
lee |
lee This is why the slots are directional....ie they should wipe from the inside out as was pictured above. |
***Threadjack****
How would slotted handle muddy condtions? Wouldnt the mud just clog up the slots? |
Here pictures worth a 1000 words.. These are my cross drilled ones but slots go the same direction (Driver side)
http://community.webshots.com/photo/...69409835qCJewR |
Greetings,
From the Brembo Brake Forum: Which direction should the discs rotate? It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use: * Straight * Pillar vane (comprised of many small posts) * Curved vane The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Please see figure. Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat. Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure. http://www.buybrakes.com/brembo/faq.html#q28 |
Originally Posted by MvCrash
.....Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure.
http://www.buybrakes.com/brembo/faq.html#q28 I run slotted rotors on all 4 corners of my Impala SS and this is the way they go.
I've changed the picture, so now the above picture IS correct.
Originally Posted by 4RUNR
What's that light brown stuff?
They as in who made the rotors? Looks exactly like primer from Sears hardware that I always spray on new rotors. Same exact color! :hillbill:
Slotted rotors are not for cooling. The slots are to remove surface glazing from overheating as well as gas venting during braking. The gas that vents is from the vaporization of the bonding agents that hold the pad material together. For these things to occur, it takes sustained high temperatures. You'd have to heat your pads up to the point they fade and then continue to use them. How many of us encounter those kinds of conditions?
Btw, I'm not saying don't get slotted rotors, they look cool and stuff but let's not kid ourselves about 'needing' performance rotors on our 4runners. |
Alan if you need a hand with that, I have nothing to do tomorrow. wheeling is not looking very likely. Or ill just well crap together around the house with my new toy. ;)
http://www.wheelersoffroad.com/4runnerbrakes.htm Powerstop brand, I got mine from the link a while ago |
