YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Set up for Dyno test (https://www.yotatech.com/forums/f2/set-up-dyno-test-20351/)
mdvga Nov 4, 2003 05:27 AM
Hey, I'm taking my 4Runner to the Dyno on Thursday of this week. I just received my Injen IS2055P but, before I install it, I want to capture some baseline HP/Torque readings.
My questions are:
1-Which gear should the test be run in?
2-Overdrive on or off?
3-ECT in normal or PWR mode?
4-Anything else I should do?
I get three runs for $75 so I want to make sure I get the most out of the test.
PS-How long will it take the ECU to adjust to the new A/F ratio and therefore be able to take it back for another Dyno run and get good (reliable) results?
Thanks for any feedback you might have.:)
Zubaltec Nov 4, 2003 06:53 AM
Dyno in Drive. Take the speed up to 70mph and then step on it. OD off.
ECT off.
John
