YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Same part? Transfer switch vs. backup indicator (https://www.yotatech.com/forums/f2/same-part-transfer-switch-vs-backup-indicator-309282/)
vagabond317 Nov 13, 2019 07:17 AM
Same part? Transfer switch vs. backup indicator 4wd
I am trying to fix my blinky-light-not-switching-out-of-4wd problem on my 2001 4Runner. Part 84222-12010 comes up in searches for a transfer switch as also being the same number for a backup indicator. Here’s my question: is there any difference? The price is Very different. The backup indicator can be purchased for less than $10 and the transfer switch is over $60. They look exactly the same. Is it the same part with a cheaper price because it had a different name? Will this work in my transfer actuator?
fierohink Nov 13, 2019 10:44 AM
They should be interchangeable. The only exception is one may have an alignment notch in the plug. If that is preventing you from plugging in just file it down.
