YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   RR DIFF LOCK --- Will Not Engage... Help! (https://www.yotatech.com/forums/f2/rr-diff-lock-will-not-engage-help-195390/)
Toy Gun Oct 28, 2009 06:50 PM
So... I have a 99 4runner, 4x4(obviously) v6.. here's my problem..
My RR Diff Lock worked fine, then i had my transmission rebuilt.. and not it will not engage..
4x4 works like a dream, low and high, but the Diff Lock won't come on.. when i put it in 4low, neutral, and hit the button, all the lights come on, i can hear something click, but the DIFF LOCK light just keeps on flashing (suppossed to stop flashing when engaged.)
any ideas ?
thanks dudes!
Elton Oct 28, 2009 07:34 PM
unplugged wire ?
Yukon Oct 28, 2009 07:42 PM
Slowly turn from side to side. If you just drive straight, it wont engage for a long time sometimes. The click makes me assume the actuator is working, and all wires are properly plugged in.
You need to be moving for it to engage. You dont need to be in neutral for the locker to engage, only to shift into 4low
96743runner Oct 28, 2009 11:51 PM
x2.
Make sure that you're moving (slowly) and have your transfer case in 4low.
Diesel and Dust May 1, 2024 06:59 PM
Oops.
